Steering Column Removal?
Old Jul 3, 2012 | 07:35 PM
Xterrable's Avatar
Xterrable
Default Steering Column Removal?
Is there a good write-up for the removal of the whole steering column? I need to remove the column so I can get the dash pad out. I saw some write ups that explain how to take the column apart, but I think that it gets unbolted and pulls out as one piece.
I have a 74 Tilt/Tele Auto Vert car.
Old Jul 3, 2012 | 09:02 PM
MrJlr's Avatar
MrJlr
ttt
Old Jul 3, 2012 | 09:14 PM
Mashman's Avatar
Mashman
In the engine compartment, you need to disconnect the column from the rag joint - loosen/remove the one screw closest to the firewall. Use a large flat screwdriver to open up the clamp a bit. Disconnect the interlock cable from the column by the firewall.
In the car, disconnect the harmonica connector. Disconnect the ignition switch connector. Remove 2 bolts at the firewall. Remove the 2 vertical bolts.
That should be it. I recommend removing the wheel, it will make it easier to handle the column. Never remove the 4 interior bolts while the column is still connected to the rag joint, you can damage the rag joint or the steering box.
Old Jul 3, 2012 | 09:18 PM
Peterbuilt's Avatar
Peterbuilt
Default Does this help?
http://willcoxcorvette.com/instructi...77_secured.pdf
Old Jul 4, 2012 | 07:06 AM
Jim Shea's Avatar
Jim Shea
This paper is quite complete on removing the steering column from the your Corvette.
http://jimshea.corvettefaq.com/wp-co...v24MY20122.pdf
Good luck,
Jim
Old Jul 4, 2012 | 09:08 AM
Xterrable's Avatar
Xterrable
Excellent! Thanks All.
Old Jul 4, 2012 | 10:04 AM
71scgc's Avatar
71scgc
Just pulled mine in prep for body-off and Tremec TKO install. Piece of cake. The hardest part was unplugging the 41-year stuck on plugs. Care should be taken so as to not damage the plugs.
BTW, Jim Shea rules!!!
To Steering Column Removal?
