Ignition Problem
Old Jul 8, 2012 | 03:41 PM
Pelayo114's Avatar
Pelayo114
I'll give it a shot right now. At least I'll try to apply 12v to the purple wire. I'll post what happens.
Old Jul 8, 2012 | 04:58 PM
Pelayo114's Avatar
Pelayo114
Is the purple wire still purple at the starter or is it in some sort of big connection? Either I have my connections wrong or the starter isn't connected with the purple wire.
Old Jul 8, 2012 | 05:18 PM
Pelayo114's Avatar
Pelayo114
Checked it all out, the solid purple wire is connected to the starter. Double checked my connections. Applied 12v to that wire and the starter cranked a bit. At least I know that wire is properly connected. Is there a way to check if its the ignition switch or neutral safety switch?
Tried tester light on the purple wire with a white line coming from the ignition switch. It has current when I move the key to the 'start' position. I check the solid purple wire, no current. Car is in park. My guess is the neutral safety switch is bad?
Old Jul 8, 2012 | 06:19 PM
...Roger...'s Avatar
...Roger...
Yep , sounds like the switch is bad IF it is adjusted properly. Did you try turning the key to START and then moving the shift lever to other gears ? Be ready in case it starts in gear !
Old Jul 8, 2012 | 06:23 PM
Pelayo114's Avatar
Pelayo114
I'll be sure to try it in a while, right now my 6 year old sister and cousins are running around the car. Don't want to risk anything there. I'll give it a few minutes so they tire out. But I'll be sure to try it and report back here. Thanks!
Old Jul 8, 2012 | 09:53 PM
Pelayo114's Avatar
Pelayo114
No luck.
Anyway I can bypass this? Maybe just hook up both purple wires together? While still keeping the white reverse lights functional.
Old Jul 8, 2012 | 10:14 PM
...Roger...
Originally Posted by Pelayo114
No luck.
That will do it ,purples together, be careful it will start in any gear !
Old Jul 8, 2012 | 10:17 PM
Pelayo114's Avatar
Pelayo114
Seeing as how I currently have a push button I'm already used to having the car start in any gear. Had a few close calls too!
Thanks for your help roger. Much appreciated.
Old Jul 8, 2012 | 10:19 PM
...Roger...
Your Welcome
Old Jul 8, 2012 | 10:24 PM
my 76 ray's Avatar
my 76 ray
It's not hard or expensive to replace the neutral safety switch. It's there for a reason.
