New Part Released Today. 68-71 Seat Belt Warning Module.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
http://willcoxcorvette.com/product_i...ducts_id=27417
Roger bugged out to early on the 4th for me to show him this.. but we finally finished this project. I didn't take him to the secret rooms up front..
We will have stock on the shelf in two weeks.
This is a solid state version of the original module. Simply transfer the two lower bolts from your old module and bolt in to your gauge cluster housing.
The picture below is the final proto-type. The actual color of the board will be in standard green board. (not noticed when installed)
Dealers will be sent wholesale sheets on this item on Monday.
We have also released the rear door ajar switch brackets for the 68-76 cars...
The original is on the left, the reproduction is on the right.... They are sold in pairs only.
http://willcoxcorvette.com/product_i...ducts_id=27418
Thank you,
Willcox
Thank you,
Willcox
Former Vendor
Well we have a fix for that.. with two positive annodes, some sodium bi-carbonate and sodium hydroxide, a cheap imported battery charger and a 55 gallon drum full of water.. you can deteriorate these as you please in a controlled environment.
Or you could put them in some salt water for a week..
Received 2,878 Likes
Hi Ernie,
NICE!
Regards,
Alan
PS: Since you have a 'formula' for 'crusty'.... do you happen to have one for 'as forged' ????
NICE!
Regards,
Alan
Nice new parts. I do know my seat belt switch will not reset right now. It used to work but I have been too lazy to pull the dash apart again to try and see what is wrong with it. With this I would not even have to mess with the trouble shooting process.
Former Vendor
Former Vendor
I'm putting instructions on the site as soon as the stock arrives.. Why? Because there is a jumper wire from the gauge to pick up power to the module.
Former Vendor
She's done..
Excuse my ignorance, but what problem does this fix? I have the push button for the seat belt on my '68 but it works fine. What is tyically breaking on these buttons? Thanks.
Former Vendor
If you are restoring a car "As Delivered" or to NCRS standards then this lamp should work. But the reason we made this was from having two customer looking for it in the same month.
Willcox
I didn't realize there is a relay associated with the seat belt pushbutton. So the relay goes bad and the light won't turn off when you push the button? Or vice versa, where the light doesn't come on at all when you start the car? Just curious. Thanks.
