headlights
Old Jul 14, 2012 | 12:19 PM
TOM B1's Avatar
TOM B1
Default headlights
installing headlights harness, how do these 4 lights work.
are the outer 2 low beams and when I turn on hi beam are all 4 suppose to go on ,are all 4 bulbs the same or are 2 just hi beams,,,,, confused.
Old Jul 14, 2012 | 12:32 PM
Alan 71's Avatar
Alan 71
Hi Tom,
The outer lamps are the low/high beams (3 wire connector), while the inner lamps are high beam only (2 wire connector).
Have you checked the position of the dimmer switch and the lighting harness ground connection?
Regards,
Alan
Old Jul 14, 2012 | 03:06 PM
TOM B1's Avatar
TOM B1
Thanks, that 27 years in box's for ya
To headlights
