Cruise Control
Old Jul 16, 2012 | 04:14 PM
RobRookie's Avatar
RobRookie
2nd Gear
Default Cruise Control
Hi all. I have a problem. I want to reinstall cruise in my 77, all the stuff is there to do that except the cruise control lever/button on the colunm. The book says it should be on the tilt lever but all the order houses say it is on the turn signal. It's a 77, the first year this came out I guess so I'm stuck. Any help would be appreciated.
Old Jul 16, 2012 | 04:23 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I believe turn signal lever is correct. It might be in the owner's manual.
Old Jul 16, 2012 | 04:56 PM
drwet's Avatar
drwet
What book are you reading that says its on the tilt lever? To my knowledge, it was always on the turn signal. I have a '79 but the column is out of a '76. Both are on the turn signal.
Old Jul 16, 2012 | 06:46 PM
wnmech's Avatar
wnmech
On my 77 the cruise button is in the tilt lever.
Old Jul 16, 2012 | 06:53 PM
xkeots's Avatar
xkeots
On my (and my others) 77 the washer and wiper is on the signal arm and on the tilt is the cruise button.
Jack
77 L-82
Old Jul 16, 2012 | 07:07 PM
REELAV8R's Avatar
REELAV8R
I have a 77 with cruise control and it is on the turn signal lever. It's not all that great, hunts a bit has a hard time holding speed. The only way to disengage it is with the brake pedal.
Old Jul 16, 2012 | 11:25 PM
7T1vette's Avatar
7T1vette
If you aren't that crazy about keeping the car entirely stock, you could purchase an aftermarket cruise control kit and hook up the 'new' control unit to the existing wiring, vacuum line and to the existing turn signal control switch. The Chevrolet Chassis Service Manual has the electrical diagram for the switch connections so that you could interface it with the 'new' control wiring. The cost for an AudioVox cruise control would be about the same as what a replacement for your stock cruise head would be.
Old Jul 17, 2012 | 12:06 AM
REELAV8R's Avatar
REELAV8R
oops got that wrong I just checked and it is on the tilt lever. Been so long since I used it guess I forgot which one it was on. wiper/washer and blinker on other lever.
Old Jul 17, 2012 | 12:31 PM
RobRookie's Avatar
RobRookie
2nd Gear
Default 77 Cruise Control
Thanks everyone for your replys. I guess the other question is, where can I get the tilt lever with the cruise control switch? Ecklers, Corvette Central, Mid America, none of them can help with this. Thanks.
Old Jul 17, 2012 | 12:58 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by wnmech
...On my 77 the cruise button is in the tilt lever...
Originally Posted by xkeots
...on the tilt is the cruise button...
Sunuvagun. Tilt lever. I did not know that. I just learned something.
To Cruise Control
