Temperature gauge issue
Old Aug 2, 2012 | 11:13 AM
MikeD72's Avatar
MikeD72
Default Temperature gauge issue
Hi my 72 vette temperature gauge has a mind of its own ?? I changed the stock radiator with a aluminum radiator and the hoses .My issue is that the temperature gauge goes hot to 230-240 degrees for 15-20mn and than drops back to 200 degrees ? Is that normal or is there something wrong ??
Old Aug 2, 2012 | 01:49 PM
MelWff's Avatar
MelWff
what temperature thermostat are you using? Are you sure you dont have air in the cooling system?
Old Aug 2, 2012 | 07:05 PM
MikeD72's Avatar
MikeD72
Hi I'm still using the stock thermostat a little rusted "should i change it ?" and how can I check if there is air in the cooling system ??
To Temperature gauge issue
