OFF current draw
Old Aug 2, 2012 | 03:06 PM
David Erb's Avatar
David Erb
7th Gear
Default OFF current draw
What is the acceptable current draw in a C3 with everything turned off except the quartz converted clock? My meter is bouncing between .01 amp and .02 amps. Asking because my battery goes dead after about a month with no charger on it. Once recently when I went to hook up my battery and sparks began to fly so I couldn't connect. I looked to the starter solenoid and heat shield above it. They once made contact before and scorched the shield. This time I removed a section of the shield and the heavy sparking went away when I went to re-hook the battery.
Old Aug 2, 2012 | 04:20 PM
MelWff's Avatar
MelWff
Install a cutoff switch on the battery negative terminal.
Old Aug 2, 2012 | 05:08 PM
scottyp99's Avatar
scottyp99
This is what I did. It works great until you forget to disconnect it. D'oh!!!!
Keep the shiny side up!
Scott
Old Aug 2, 2012 | 05:12 PM
Mike Ward's Avatar
Mike Ward
Zero.
To OFF current draw
