Harmonic balancer slipped
Old Aug 6, 2012 | 01:26 PM
VetteNURSE's Avatar
VetteNURSE
Default Harmonic balancer slipped
If my Harmonic balancer has slipped does this mean its not balanced any longer? Do I need a new one or can I just re mark TDC?
Thanks ,
Mike
Old Aug 6, 2012 | 01:41 PM
Shark Racer's Avatar
Shark Racer
Buy a new one... and don't get a professional products one. (professional products dampers only work if you have procomp heads )
Old Aug 6, 2012 | 01:46 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
It's still balanced..unless it's an external balanced engine with a carved out spot in the outer ring. Most have added weight on the hub part...but either way...
YES..you need a new one...NOW! When they slip they are very prone to coming apart violently. The outer ring is no longer attached strongly to the center hub and it's going to keep getting worse. Best case is it only slips back against the timing cover and eats a hole in it. Worst case is that the ring ends up cracking and flying off at an inopportune time..like when going through the gears..or why you're staring at it trying to set the timing.
You dont have to have a high $$ fancy one..but you need a good one.
JIM
Old Aug 6, 2012 | 04:13 PM
Jeff_Keryk's Avatar
Jeff_Keryk
I used Damper Doc; he replaced the elastomer (?) and degreed the outer ring.
Might have been cheaper to buy another, but I kinda like the old stuff...
Old Aug 6, 2012 | 05:56 PM
redvetracr's Avatar
redvetracr
I have this brand new one available, if you or anyone else is interested
send a PM...
Old Aug 6, 2012 | 06:08 PM
Trae1976's Avatar
Trae1976
Just like this, though mine hadn't worn completely through the timing cover yet:
Old Aug 6, 2012 | 06:40 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
No personal insult intended but that is a really, really ugly engine for a corvette. I see it is partially disassembled. Spray paint is cheap.
Old Aug 6, 2012 | 08:46 PM
Shark Racer
The balancer was smoothing out the timing cover for him. 33% less prep work.
Old Aug 7, 2012 | 07:59 AM
Trae1976's Avatar
Trae1976
That's what the engine looked like when I got the car.
I put exactly 0 miles on it like that, it was one of the first things removed.
It's a bit cleaner in there nowadays. Heck, it's not even the same engine.
I like the machined look!
Old Aug 9, 2012 | 08:20 PM
63mako's Avatar
63mako
Way to go!
Old Aug 9, 2012 | 11:15 PM
TimAT's Avatar
TimAT
Good thing you replaced that engine- the original looks like the only thing holding the timing chain from jumping is the amount of goo caked on it.
Old Aug 10, 2012 | 09:01 AM
63mako's Avatar
63mako
Xray vision?
Old Aug 11, 2012 | 12:21 PM
pauldana's Avatar
pauldana
Fluiddamper..... it is an amazing damper, worth the $$
Old Aug 11, 2012 | 12:51 PM
redvetracr's Avatar
redvetracr
not if you want to get your rotating assembly balanced...
Old Aug 11, 2012 | 12:56 PM
pauldana's Avatar
pauldana
My rotating assembly was balanced, without the neutrally balanced fluid damper. and then added.... i shift at 6500-7000rpm... and it is as smooth as you could ever imagine...
Old Aug 11, 2012 | 02:49 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
There was one member, can't remember who, *Tshort* comes to mind. I think he is still here, but he bought a Lucky Products balancer and said he took for a drive, came home parked it overnight and when he came out in the morning the balancer was on the floor under his Vette
Old Aug 11, 2012 | 09:23 PM
terry82's Avatar
terry82
Are these better than the factory dampers .Is one damper really any better?
To Harmonic balancer slipped
Old Aug 12, 2012 | 01:02 AM
pauldana's Avatar
pauldana
Well, I'm sure there will be comments on both sides of the fence here, but for me I believe that it in fact did cut down on my vibration.... i run a 383 and it is absolutely smooth as any new modern vett.
Old Aug 12, 2012 | 07:43 AM
b71vette's Avatar
b71vette
pauldana - do you have the Fluidamper part# you are running on your 383? Are you running the stock water pump and alternator pulleys?
Old Aug 12, 2012 | 08:57 AM
MotorHead's Avatar
MotorHead
There is only one that my friend who owns an engine shop will put on any serious motor and that is the ATI Super Damper
I have this one on my 427 it is SFI 18.1 rated and is NHRA / IHRA and NasCar approved there is one almost the same but $90 cheaper in price ATI-917781, the only difference is steel outer shell as opposed to aluminum
http://www.summitracing.com/parts/ATI-917782/
You probably don't need this type for your engine, just showing you what is out there and available
