Harmonic balancer slipped
Old Aug 12, 2012 | 08:40 PM
b71vette's Avatar
b71vette
Originally Posted by MotorHead
There is only one that my friend who owns an engine shop will put on any serious motor and that is the ATI Super Damper
I have this one on my 427 it is SFI 18.1 rated and is NHRA / IHRA and NasCar approved there is one almost the same but $90 cheaper in price ATI-917781, the only difference is steel outer shell as opposed to aluminum
http://www.summitracing.com/parts/ATI-917782/
You probably don't need this type for your engine, just showing you what is out there and available
Thanks for the info. MotorHead
Old Aug 13, 2012 | 05:30 PM
pauldana's Avatar
pauldana
Originally Posted by b71vette
pauldana - do you have the Fluidamper part# you are running on your 383? Are you running the stock water pump and alternator pulleys?
http://www.fluidampr.com/product/620101/
http://www.summitracing.com/parts/FL...ET&prefilter=1
After market March under-drive aluminum pulleys.
After market Bosh aluminum water pump.
Aftermarket 120Amp alternator.
Old Aug 13, 2012 | 07:05 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Brand new Nascar engine from Roush/Yates
Hendrickmotorsports Nascar engine
If these guys put a $300 ATI Damper to balance a $60-80,000 engine there must be a reason
Like I said you probably don't need one then again you probably don't need a fliud damper either a $40 stock one is sufficient any brand but don't buy one from Chevy HotRod capitol of the world, Guangdong China
Old Aug 13, 2012 | 09:15 PM
b71vette's Avatar
b71vette
Pauldana and MotorHead, thanks for the info. and pictures. Those NASCAR engines are impressive looking machines.
I was leaning towards the FLUIDAMPR because I recently installed one on my stock Dodge Cummins diesel with an automatic and have been quite pleased with it. The auto shifts smoother from take off all the way to OD. And at highway speeds the engine runs smoother. FLUIDAMPER claims to dampen out the harmonic vibrations thru-out the entire RPM range and it appears to be working on this big inline six diesel. So I was thinking the FLUIDAMPR might further reduce some of the vibrations in my 383 stroker with solid motor mounts. Presently, vibrations aren't bad at all but just thought it may help even more and plus I want to get that Professional Products damper off since I've heard bad things about those. Another benefit of the FLUIDAMPR is there is no inner elastomer rubber ring to worry about having to replace down the road after it ages and gets cracks in it.
Thanks again for your alls help.
Old Aug 13, 2012 | 09:42 PM
cv67's Avatar
cv67
St. Jude Donor '05
THere is nothing wrong with a fuidampner
If you use the ATI you may have to hone to fit they go on a little tight.
Dont force it on youll never get it off. THey are a nice piece btw.
OP get rid of that balancer now!!
Had one explode on me years ago went right through the hood took out the radiator and everything on the front of the motor. Like a small hand grenade went off.
Old Aug 23, 2012 | 08:06 PM
Terry1218's Avatar
Terry1218
Cruising
Default Harmonic balancer
Originally Posted by redvetracr
I have this brand new one available, if you or anyone else is interested
send a PM...
I may be interested. The one on my 1978 came off (with a puller in 2 pieces). I am a machinist so I thought maybe I could pin it...but I don't know what the true position of the inner hub (with the keyway) with respect to the timing mark on the outer ring. Is this advisable? Funds are a problem right now...How much for your's? Terry422914@aol.com
Old Aug 24, 2012 | 02:44 AM
Bud2's Avatar
Bud2
Bud2
Was just thinking, didn't I read on the Scat site that they don't recommend the/any fluid damper??? I could be wrong.
Bud.
