Starting problem PLZ HELP!!!
Old Aug 7, 2012 | 05:18 PM
77vetteluva's Avatar
77vetteluva
Just a thought--If the neutral safety switch is a little out of alignment on the shifter it may not start in P or N. Mine was out and if you nudged the shifter a bit the switch would close. Only had to align the switch properly to fix the problem. Try moving the shifter a little while turning the ignition switch to start. You may get an answer with little effort.
However this is no replacement for getting a meter or test light and confirming the diagnosis. Part swapping is a pet peeve of mine. Spent most of my working life troubleshooting HVAC controls and seen a lot of guys replacing parts on a guess. That's very expensive and time consuming unless you just lucky. I'm not seeing that(lucky) here.
~Rick
Old Aug 7, 2012 | 05:28 PM
noonie's Avatar
noonie
Originally Posted by lvmyvt76
why is that everyone starts replacing parts instead of buying a cheap test light or meter to check things out??? Its usually a lot easier to check things than to lay on your back to change part after part after part, and still not start? It would of paid for a very expensive meter by now!
~Rick
From the numbers in his first post it seems he does have a meter.
Will he use it?
Old Aug 7, 2012 | 08:55 PM
78 t-tops's Avatar
78 t-tops
Cruising
I have a multimeter my original starter was bad and my battery wasnt good . Well on the bright side I bypassed the ignition with a push button and it cranks , so I went and bought a new ignition switch and will probably install it tomorrow so at least I was able to hear the car turn over great noise considering I bought the car like a month ago and between the wife and work only had a hour or two a night to work on it .
Thanks for all the advice guys
Old Aug 7, 2012 | 09:12 PM
78 t-tops's Avatar
78 t-tops
Cruising
I will still check the neutral safety switch though
Old Aug 8, 2012 | 02:13 PM
77vetteluva
I assume that means you conformed there is no continuity through the ignition switch when you turn it. Right?
Old Aug 9, 2012 | 12:18 PM
78 t-tops's Avatar
78 t-tops
Cruising
Yep you are right I checked the neutral safety and it checked out fine when I started checking the ignition switch it didn't hold but a few times , so it runs but I think I either have a vacume leak or bad actuators because the lights come on but do not come up , as well as the gauges don't work but I think it's just a fuse or loose wire hopefully so I will be checking those in the next day or so I'm more interested in running it a bit and letting some of the old gas burn off
