timing uncertainty!again!
Old Aug 7, 2012 | 03:55 PM
smyth1's Avatar
smyth1
Default timing uncertainty!again!
thought i had the timing dialed in on my 69 small block until i talked to a holley tech.i timed it at 35 cetrifigal.idle timing came in at 16.with the vacumme advance hooked back up i have 53 total timing.holley tech says thats way too much.total should only be 36- 38.
Old Aug 7, 2012 | 03:57 PM
'75's Avatar
'75
Pay no mind, he apparently doesn't understand vacuum advance.
Old Aug 7, 2012 | 04:06 PM
Mike Ward's Avatar
Mike Ward
And probably not much more about carbs.
Old Aug 7, 2012 | 05:43 PM
noonie's Avatar
noonie
He probably meant at idle.
Old Aug 7, 2012 | 06:13 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Tech is correct for mechanical advance, with vacuum advance connected it can go to 53 deg. or more
Just reread how do you know it goes to 53 degs ? with the vacuum advance, always interested in knowing something new
Old Aug 7, 2012 | 07:11 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
If you at 16 initial, 35 total (initial and centrifugal), all in by 2600-3000 and 53 max with initial, centrifugal and vacuum advance your golden. The holley tech could be a high school kid with a summer job dad got him, you never know.
Old Aug 7, 2012 | 07:56 PM
TimAT's Avatar
TimAT
I've heard that one of the major retail hot rod parts stores uses the magazines in the break room method to train their telephone sales reps
Old Aug 7, 2012 | 09:00 PM
scottyp99's Avatar
scottyp99
Well, if your initial timing is 16, and full centrifugal advance is at 35, then all you have to do is plug in the vacuum advance. If the ignition timing goes up to 34 at idle, then 18 of those degrees must be from vacuum advance, right? 35+18=53, and voila!! Easy, peasy, lemon-squeezy!
Keep the shiny side up!
Scott
Old Aug 7, 2012 | 09:28 PM
lars's Avatar
lars
The Holley tech is misunderstanding you. "Total timing" is normally defined as the max timing you see with the centrifugal "slammed" all the way in, but with vacuum advance disconnected. "Total timing" should be 34-38 degrees for best power and performance on most small block gen1 engines. Just like you have it. Just like he stated.
Vacuum advance is very misunderstood by most people. For this reason, I have written the "Vacuum Advance" tech paper in cooperation with Duke Williams and John Hinckley - two of the most respected automotive engine engineers in the world. Please drop me an e-mail request for this paper if you need clarification on the vacuum advance principles. Bottom line is this: Your "total timing" is perfect. Your vacuum advance is also perfect, but could be reduced by perhaps 4 degrees, but this is not enough to cause any concern or issues. The "total combined timing" (full centrifugal advance plus the vacuum advance) at 53 degrees is perfect, and should give you actual timing at idle of about 30-some degrees for very good engine operation. With the current burn rate of modern pump gas, we see that this "total combined" timing could be reduced to about 47 degrees, if the car is "jerking" or "trailer hitching" at cruise speed. Otherwise, you got it nailed!
Lars
V8FastCars@msn.com
Old Aug 8, 2012 | 08:12 AM
smyth1's Avatar
smyth1
thought i had it right.i am still trying to dial in the carb.getting some sputtering under acceleration and no color on plug readings.i did throw 12 gallons of av gas in on initial start up. i may go up a few jet sizes.
Old Aug 8, 2012 | 02:14 PM
RSVETTE's Avatar
RSVETTE
We need all of Lars papers on a sticky.....
Old Aug 9, 2012 | 10:54 AM
MotorHead's Avatar
MotorHead
Scott
I get it now, simple math why couldn't I figure that out, thanks.
I didn't know you get the highest manifold vacuum, therefore the highest ( in degs ) vacuum advance at idle, you learn something new every day
To timing uncertainty!again!
