TPS Setting
Old Aug 12, 2012 | 06:45 PM
Wrecked82's Avatar
Wrecked82
Default TPS Setting
Why does my TPS setting float? I set it within specs and after time, its out of spec. Replaced TPS twice so that is not the problem. Oh, it's an 82.
Old Aug 12, 2012 | 08:05 PM
terry82's Avatar
terry82
one reason could be that the movement inside the tps wears some everytime you move it .i found the metal arm from the tbi that the tps goes to can bend .i think the tps switches are verry cheaply made.
Old Aug 12, 2012 | 08:17 PM
7T1vette's Avatar
7T1vette
Poor electrical connections? Bad wiring? Poor electrical ground?
Old Aug 12, 2012 | 08:21 PM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
Check for linkage wear from the pedal all the way out. A stronger return spring can also help maintain the initial setting.
To TPS Setting
