Making Fuel Line,..Quick Question
Old Aug 14, 2012 | 11:30 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Default Making Fuel Line,..Quick Question
In the past I've used the 6' fuel line from GM, part number 22527595, cut a length from each end coupled it with the C4 fuel filter, AC Delco # GF652F, then double-flared the ends of the line that mate to the carb and pump. Worked and looked great.
GM # 22527595 is discontinued and not to be found. I think I've found a replacement in the Dorman catalog but wanted to check first. Does anybody know if this repair line:
http://www.summitracing.com/parts/RNB-800-157/
...will work with this filter?:
http://www.ebay.com/itm/ACDELCO-PROF...sories&vxp=mtr
Thanks in advance.
Old Aug 15, 2012 | 11:31 AM
69 Chevy's Avatar
69 Chevy
Too bad no one's coming forth with a QUICK answer.
Old Aug 15, 2012 | 11:38 AM
lvmyvt76's Avatar
lvmyvt76
that's probably because we order the pre-bent fuel lines from a vendor and don't make our own.
Old Aug 15, 2012 | 11:52 AM
69vette19467's Avatar
69vette19467
This may be what you want. Got this at Advance Auto - Dorman 800-153 Quick Disconnect 3/8" X 18" Fuel Line Repair. It's got an o-ring flare at one end and plain at the other. Will save you time and shipping costs.
Old Aug 15, 2012 | 01:03 PM
lars's Avatar
lars
Yes, that line will mate to the C4 filter.
Lars
Old Aug 15, 2012 | 05:26 PM
73, Dark Blue 454
69V,..Yeah, that's the same thing only the one I referred is 30" vs. 18". I was thinking 18" from the filter-to-carb and I'd need more than 18" pump-to-filter.
Old Aug 15, 2012 | 05:27 PM
73, Dark Blue 454
Lars
Good deal! Thanks everybody!
To Making Fuel Line,..Quick Question
