soot in exhaust
Old Aug 17, 2012 | 05:00 PM
BHRIG's Avatar
BHRIG
Default soot in exhaust
77 -350,edelbrock 1406, timing advance 14 degrees @750 Rpm, 32 degrees@2600 rpm, 51 degrees @ 5000 RPM... new plugs, wires......
car idles and runs great......no misses, no hesitation...no gas odor...
sounds good? Why is soot (excessive unburned fuel) forming on interior
of tail pipes........
Old Aug 17, 2012 | 05:40 PM
Shark Racer's Avatar
Shark Racer
Cars will idle and accelerate real good running a little bit rich... and put out black smoke.
Needs tuning. Get a wideband and go to work!
Old Aug 17, 2012 | 07:52 PM
ED79's Avatar
ED79
Maybe adjusting the carb air mixture screws out or in to maximum vaccum with vaccum gauge. Both screws should be turned out about the same number of turns. Hope this will help some... ED
Old Aug 17, 2012 | 08:04 PM
BHRIG's Avatar
BHRIG
Carb has been adjusted to maximum rpm with vacuum.....
How would adjusting timing closer to 6degrees affect the burn...
richer or leaner, or no affect?
Old Aug 17, 2012 | 09:18 PM
Shark Racer
Timing will have an effect, but what you should be chasing is carb mixture.
I'm not familiar with tuning an Edelbrock, but I'd imagine that primary metering rods are what you're after. Are you seeing black smoke at idle only, or idle+cruise? Actually, a little blackness on the inside of your tailpipes is not worrisome.
It's black smoke you should be concerned about. Use a wideband or smog sensor.
Old Aug 17, 2012 | 11:12 PM
BHRIG's Avatar
BHRIG
I don't see any smoke.........I found soot accumulating inside exhaust tips
Old Aug 17, 2012 | 11:21 PM
lars's Avatar
lars
If you're running current pump gas with 10% federally mandated ethanol, the inside of the tailpipes will be black and sooty no matter how you tune the engine. If you want the pipes to turn light grey, go put a tank of $12/gal race gas with no ethanol in the car and enjoy the color... We see black exhaust components using ethanol-"enhanced" pump gas even on the dyno with the engine absolutely optimized and running with red-glowing headers. Nothing you can do about it as long as the corn-growers' lobby is making you run ethanol in the fuel.
Lars
Old Aug 17, 2012 | 11:22 PM
Shark Racer
Perfectly tuned cars will have a bit of soot. WOT timing for power is richer than stoich.
It's constant sooty exhaust you need to worry about. Are the bumpers loading up with black dust?
Old Aug 17, 2012 | 11:25 PM
BHRIG's Avatar
BHRIG
As usual, Lars, you are the man!!!
I was looking for a problem that does not exist.....
I guess now I will look for something else to "FIX"!!
It is a disease we all suffer from.
Thanks!
Old Aug 17, 2012 | 11:28 PM
BHRIG's Avatar
BHRIG
Racer,
The soot is lining the inside of the exhaust tips..
plugs are clean.
Old Aug 17, 2012 | 11:35 PM
Shark Racer
Originally Posted by BHRIG
Racer,
plugs are clean.
Call me Shark, Sharky, or Steve.
Soot coating the exhaust tips is normal. (see post 5)
Black exhaust smoke is not, that's an indicator of running heavy rich.
If you are interested in knowing where you are, start with a gas analyzer tool. Then, finalize with a dyno or a stopwatch.
There are other techniques as well, but I'm not familiar with the Carter style carbs.
A car will run very smoothly and still leave power on the table.
Old Aug 18, 2012 | 12:27 AM
BHRIG's Avatar
BHRIG
Thanks.....Shark!
Other than the soot, which is normal for "corn fuel" according to Lars and you,
the vehicle is running better than it has in 12 years......
Old Nov 16, 2020 | 04:42 PM
Aussie C3's Avatar
Aussie C3
6th Gear
Default Soot building up on paintwork around exhausts
Yes, that’s my issue. Any tips for removing the soot?
Old Nov 16, 2020 | 04:54 PM
'81 Vette's Avatar
'81 Vette
Might be worth starting your own thread, this one is 8 years old. 8;
Old Nov 16, 2020 | 05:15 PM
Aussie C3's Avatar
Aussie C3
6th Gear
I Thought a post would place it up near the top. Probs wrong cheers
Old Nov 16, 2020 | 07:08 PM
Shark Racer
I can't remember what I was on about back then - try car wash soap, if that doesn't work, then a clay bar, then polish. Try to minimize soot by making sure your car is well-tuned, and also the outlets of your exhaust system should clear the bumper by a bit. If the tips abort too close to the paint work the panel will soot up.
Old Nov 17, 2020 | 12:52 AM
Haggisbash's Avatar
Haggisbash
Some carb cleaner on a cloth will get rid of the soot - only from metal of course!
Old Nov 17, 2020 | 07:27 AM
augiedoggy's Avatar
augiedoggy
Lars
Since someone revived this thread from the dead,
I believe this depends on where you live. Around here they sell ethanol free premium gas at many gas stations its what I use 99% of the time.
To soot in exhaust
