Hooker or dynomax?
Old May 30, 2002 | 03:39 PM
Justin79-L-82's Avatar
Justin79-L-82
Default Hooker or dynomax?
I'm going to order either the hooker or dynomax creamic coated headers, which ones should i get???????????
Old May 30, 2002 | 03:42 PM
Ryan77's Avatar
Ryan77
Default Re: Hooker or dynomax? (Justin79-L-82)
The dynomax's are cheaper, but from what I hear the hooker's are less restrictive due to larger primary tubes.
Fevre's Avatar
Fevre
Get the hooker first then if she doesn't take all your money get the dynomax. :yesnod: :jester
Old May 30, 2002 | 03:45 PM
70PurpleLS7's Avatar
70PurpleLS7
Unless you have/or are building something that needs those big tube headers, the Dynomax brand will work just fine. The cost is roughly half of what hooker wants and it seems like most people on this board who have purchased Dynomax are quite happy with them.
[Modified by 70PurpleLS7, 2:46 PM 5/30/2002]
Old May 30, 2002 | 04:30 PM
Mack's Avatar
Mack
I'll give you a definite "Maybe."
All kidding aside, I've got Hookers and I really like them. There are others who are equally satisfied with Dynomax, Heddman and other brands. If I had it to do over, I'd get all the comments I could from the forum members, do a little research into performance and prices on the web, and then buy what I thought was the best combination of performance and price that I could afford. Would it be Hookers? Probably, because that's what I did the first time. :yesnod: You might come up with a differrent solution.
Old May 30, 2002 | 04:46 PM
vettfixr's Avatar
vettfixr
I've got Dynomax's on mine and the only problem I had was one of the pipes hit the Z-bar slightly. A few raps of a hammer and that was fixed. I can honestly say that the headers made a nice improvement in performance. For the money I don't think you can go wrong with Dynomax. Just make sure you get good gaskets to go along with them. I used the Percy's aluminum gaskets for the headers and collectors. Retighten all the bolts after every couple of hours of use for about the first two weeks and you should be in good shape. I also used the Stage 8 locking bolts. Here's a tip, don't put on the locks until your done retightening the bolts for a couple of weeks. They're a pain in the butt to put on and off.
Old May 30, 2002 | 05:55 PM
molchaser's Avatar
molchaser
I recently installed Hooker super comps and couldn't be happier. They went in very easy, plugs are reasonably accessable, and I ran wires vertically on outter edge of valve covers and dropped right onto plugs.
As of yet I have not seen an starter issues, tho it does look pretty close. I am still chasing a few gasket leaks, a couple of the bolts are tough to get on but all in all I am quite please. Coupled with true 2 1/2" pipes and flowmaster 50's. It has made the otherwise stock L48 pretty snappy
Old May 30, 2002 | 09:51 PM
79er's Avatar
79er
Default Re: Hooker or dynomax? (molchaser)
Another vote for Dynomax Headers. I've had them on my 79 for about 2 years now and am very pleased. I do recommend a set of ARP headers bolts and Metal header and collector gaskets.
Old May 30, 2002 | 10:00 PM
Ganey's Avatar
Ganey
Default Re: Hooker or dynomax? (79er)
Dynomax coated flow well beyond what is commonly known.
Several of us know. One ex. from someone else:
StingrayRacing
I think if you're under 500hp the Dynomax are fine...I made 445hp to the wheels with them...although we did open up the ports a bit.
Rich P
72 Stingray 383 DFI 6 Speed 438rwhp/414rwtq
AFR210's, Solid Roller, Wheels: 17 x 8 w/255's & 17 x 9.5 w/285's
VB Front Transverse & Rear Glass Springs
Best 2000 Times:
11.54 @ 120.47 60'1.72 On Hoosiers( 1 5/8 Headers)
11.60 @ 120.26 60'1.68 On Nittos (with 1 3/4 headers)
[Modified by Ganey, 6:40 AM 5/31/2002]
Old May 30, 2002 | 10:36 PM
theanswriz42's Avatar
theanswriz42
Cruise-In 8 & 10 Veteran
St. Jude Donor '08, '15
As I said in another thread...I've got hooker headers and can't knock it. They are still affordable and not restrictive at all. I've only noticed a problem going over speed bumps but that's ok, you'd probably get that with any set of headers you put on the car.
Old May 30, 2002 | 11:34 PM
Zane's Avatar
Zane
Default Re: Hooker or dynomax? (vettfixr)
My Dynomax's fit great and cleared all parts with room to spare. The only problem I had was that I had to file one of the bolt holes to make the bolt fit. This was easy to do. I just had mine done about 7 weeks ago. I used Fel-Pro gaskets from summit FPP-1404 and they worked great with no leaks. I also used the 12 point ARP bolts from summit ARP-400-1201.
Hay Vettfixr what is A Z-Bar? Is that one of the supension or stearing parts?
Hay Justin look at MG62 post on his ZZ4. He has A pic there of some Dynomax headers on his new motor and they look good :yesnod: .
[Modified by Zane, 8:47 PM 5/30/2002]
Old May 31, 2002 | 12:28 AM
razz1980's Avatar
razz1980
Default Re: Hooker or dynomax? (Zane)
after new shocks headers will be my next purchase..ive researched and heard all the opinions and decided on dyno's months ago..just be glad u dont have to paid the shipping costs like i do..its $98 for shipping to hawaii :mad :cuss :cuss
Old May 31, 2002 | 08:26 AM
Jvette73's Avatar
Jvette73
Default Re: Hooker or dynomax? (razz1980)
I got the Dynomax and love em. Fit good, look good, work good. Need i say more.
Old May 31, 2002 | 01:59 PM
VettePower's Avatar
VettePower
I will take a blond hooker anyday!!! :yesnod: Oops sorry, what was the question??? :crazy:
Old May 31, 2002 | 02:10 PM
Alwyn678's Avatar
Alwyn678
Default Re: Hooker or dynomax? (Ganey)
StingrayRacing
Rich P
Best 2000 Times:
Old May 31, 2002 | 02:11 PM
70PurpleLS7
Zane, the Z-bar is the bar (lack of a better word) that is the common link between your clutch pedal rod and the linkage from the bell housing. Attaches to a support coming off the frame and to the engine block, pivots back and forth when clutch is depressed.
Old May 31, 2002 | 03:14 PM
Justin79-L-82
Default Re: Hooker or dynomax? (70PurpleLS7)
i just checked my local parts supplier and i can't order any dynomax's. They said they were on back order, and they couldn't even get prices for them. SHould i order from summit or jegs?!
To Hooker or dynomax?
Old May 31, 2002 | 03:20 PM
Alwyn678's Avatar
Alwyn678
Jegs offers FREE Shipping........Go with whoever is Cheaper :cheers: don't forget the A.C bracket if you have A/C
Old May 31, 2002 | 03:31 PM
ylose's Avatar
ylose
Default Re: Hooker or dynomax? (Alwyn678)
I too am running Dyno's ....no complaints and no fitting restraints.
dropped in without a hitch. :yesnod:
Old May 31, 2002 | 03:36 PM
Justin79-L-82
Default Re: Hooker or dynomax? (ylose)
i called summit and jegs.. both are on backorder from dynomax :mad not impressed :nopity
