ebrake question
Old Aug 18, 2012 | 07:13 AM
phclub's Avatar
phclub
New England Events Coordinator
Default ebrake question
I am planning to put my ebrake in working order (with stainless steel components), I have been without since 03. My question is; do I have to disconnect the brake line (on the TA) in order to move the caliper assy away from the rotor? Or can the caliper assy be safely moved by gently bending the steel brake line?
Old Aug 18, 2012 | 07:53 AM
Mooser's Avatar
Mooser
If you remove the clip on the T/A where the flex and solid lines meet it will allow the caliper to move around enough to tie it out of the way.
Mooser
Old Aug 18, 2012 | 07:56 AM
Alan 71's Avatar
Alan 71
Hi phc,
I believe that if you remove the clip that holds the connection of the formed steel brake line and flex brake line to the trailing arm, you'll be able to safely move the caliper around.
Regards,
Alan
What percentage of old Corvettes have working e-brakes?
Old Aug 18, 2012 | 08:39 AM
dar322's Avatar
dar322
St. Jude Donor '12-'13
hey alan, i have the ss e-brakes and have had them adjusted correctly....but they still wont stop the car. also have the orig clock and it works...but the second hand fell off. and the low fuel warning light works too, but it seems to glow more than I care to see it.
Old Aug 18, 2012 | 11:16 AM
Alan 71's Avatar
Alan 71
Hi Mooser,
I didn't mean to be an 'echo'.
STILL a slow typist after all these years. But the boss hired me to be his secretary 40 years ago because of my great legs, not because I could type.
Regards,
Alan
Old Aug 18, 2012 | 11:21 AM
Alan 71's Avatar
Alan 71
Hi d,
If the second hand is still there I'll bet it could be CAREFULLY pushed back on.
I'd say that the e-brake was designed to hold the car on the level REAL well, on a hill KINDA well, and to SLOW the car.... not so well!
If you strap two 5 Gallon gas cans to the rear deck and use some garden hose, the low fuel light won't glow so often!
Regards,
Alan
Old Aug 20, 2012 | 05:41 PM
Mooser's Avatar
Mooser
Originally Posted by Alan 71
Hi Mooser,
Regards,
Alan
Hi Alan
Your answer came 3 minutes later because you actually put thought into it and made sure it made sense and was correct whereas I usually just type out the first thing I think of and hit submit
Mooser
Old Aug 20, 2012 | 06:55 PM
johnmb's Avatar
johnmb
Define "working"
Old Aug 20, 2012 | 08:04 PM
flyeri's Avatar
flyeri
I don't think these things could ever be defined as an emergency-brake, maybe a parking-brake. There is not enough brake pad there to stop a go kart and I'm not sure it was ever designed to do any stopping.
Old Aug 20, 2012 | 08:14 PM
Mike Ward's Avatar
Mike Ward
It's called an 'emergency' brake because if you rely on it to stop the car, that's the ward at the hospital you'll end up in.
Old Aug 21, 2012 | 06:39 AM
Alan 71's Avatar
Alan 71
Hi John,
Check post #8 for 'working'!
Regards,
Alan
To ebrake question
