Rear Sway Bar
Is there a rubber bushing between the frame and the cross member that the differential bolts to? I could not tell from the diagram.
Also, did all '73s come with a rear sway bar? I can find no indication that mine had one.
350 4 spd.
One side can be higher than the other for a number of reasons: body mount bushing collapse; body mount rustout; frame damage from an earlier wreck; improperly installed leaf/monoleaf spring; defective shock absorber on one side; worn out leaf spring; different adjustment on spring-to-T/A links.
Don't worry about the lack of a rear bar unless you know (and understand why) your car needs one (or not).
Thanks for the sway bar info....that is what I was thinking, but was looking for confirmation.
The question that wasn't answered was....is there a rubber donut between the frame and the rear crossmember? I'm guessing there is, I am measuring about 1/2" difference in distance to the frame from side to side.
Non stock tires. Will definitely have to get longer bolts for the spring/TA links for the height. Need to get the back level first
The frame mount for the differential does have a large rubber bushing pressed into it. The differential cross member has a corresponding metal 'dome' that slides into the cavity in the bushing. It's designed to be a very snug fit and sometimes is ALMOST impossible to get apart. (Think 6' long pry bar!)
There is one bolt on each side that hold the crossmember in place.
Your right in thinking the differential cross ember should be the same distance from the frame cross member on each side.
It might not be the only cause of your ride height difference but could certainly be part of it.
Regards,
Alan
