1. What is the default position of a vacuum controlled heat riser valve on a stock 76?
2. I've got a good sized exhaust leak around my riser valve...used the old garden hose stethoscope trick to find it. How on earth does a guy go about sealing this up?
Hi B,
I believe the heat riser's valve's weighted lever is up in the cold/closed condition and down in the hot/open condition.
Do you know if the extra internal sleeve is in place and that the sealing donut/gasket is in good shape?
Regards,
Alan
Interesting! The General changed that somewhere along the years. MY 1969 does not have the vacuum diaphragm operated heat riser. OP has a '70, not sure if they started then or later. Anyone???
Pete
Originally Posted by Brcmpbl
Hello folks. Two questions for the educated:
The OP asked about a 76 The vacuum heat riser was a 75-79 item
Hi,
I believe the heat riser was operated by a bi-metallic coil, (think choke coil), through at least the 72 model year cars.
I've also read that the exhaust flow from high rpm also contributes to opening the 'flapper' in the heat riser.
Regards,
Alan
Hi guys...I also have a 70, and it has the "mechanical" coil style valve on it.
My 76 is the vacuum operated fella...and I think you're all correct about the default being open. This is good because I was worried it was stuck closed, but this can't be the case because vacuum would close the valve (rod would move up), etc. I feel good there.
My remaining problem is that I'm sure there's a leak where the intermediate pipe flange meets the bottom of the valve. Not sure how to repair this. Can't comment on the donut and the sleeve...haven't been in there yet. Perhaps these are the issue. It makes a very audible sputter at idle that gets quite loud under load.
So he did. My most humble apology for making an out of context remark. Hopefully the Internet gods will smile upon me soon, and not banish me to eternal darkness.
Had this fixed the other day at a muffler shop just like you guys recommended...took them one hour and it was the riser and associated bolts. Sounds like a different car, oddly quiet really. Thanks for the help.
