ECM Fault code 51 on 1982 - best fix?
Old Sep 3, 2012 | 10:38 PM
CDN3g's Avatar
CDN3g
Default ECM Fault code 51 on 1982 - best fix?
I have a Check Engine fault code 51 which, according to the code reader manual as an ECM problem on my '82. The car does start and run, although it does have a slight miss when cold. Drivability improves as it warms up.
Do I need to replace the ECM ? I noticed that Eckler's sells a rebuilt ECM but they instruct to reuse the PROM from the original ECM. Does anyone have any experience with this particular fault code and what remedy do you recommend? Thanks
Chuck
Old Sep 4, 2012 | 09:00 AM
jdp6000's Avatar
jdp6000
Chuck
Make sure the plugs at the ECM are in secure. Clear the code and see if it comes back.
You may have some corrosion inside the ECM in the area of the prom. If its not seated right or one of the pins is bent you will get that code. Look for evidence of corrosion.
New ECM's don't come with the prom. You need to swap out yours.
Old Sep 4, 2012 | 09:39 AM
7T1vette's Avatar
7T1vette
Also make sure any grounding wires/connections are clean and solid. If the Check Engine Light (CEL) is lit when the key is turned to ON position, and it goes out after the engine is started, then the ECM is "working". But, bad electrical/ground connections can cause errors in its data, which could be the reason for the Code 51.
Removing cables, cleaning contacts, and reinstalling with dielectric grease on those connections is the first step in analyzing your problem, since the trouble codes pointed to the ECM. There is no clear indicator of an ECM problem, as a defective ECM would not be reliable/accurate enough to diagnose itself as a problem. An exchange of the ECM is the last item on the list when everything else has been ruled out. Start with clean connections.
Old Sep 4, 2012 | 10:28 PM
CDN3g's Avatar
CDN3g
Thanks for this very practical advice. I have other things to spend my Corvette fund money on besides a new ECM.
Chuck
Old Sep 6, 2012 | 10:39 AM
1yy07's Avatar
1yy07
Default 82 ecm
chuck, if you need a new ecm old gm#1225550, new gm#19143616.acdelco#218-12250
To ECM Fault code 51 on 1982 - best fix?
