Rear strut rod problem
Old Sep 7, 2012 | 06:30 PM
Corvette Kiwi's Avatar
Corvette Kiwi
Default Rear strut rod problem
I recently pulled the whole rearend setup from my 1969 Corvette so that I could sand/paint the frame, clean/paint the rearend, and install new bushings and such. I also bought a new F-41 rear spring, Bilstein shocks and new adjustable strut rods. (http://www.mamotorworks.com/corvette...d=strut%20rods)
When trying to install the new strut rods the fore/aft alignment between the differential mount bracket and the trailing arm is off by over an inch when the rear suspension is hanging down. If I lift up (compress) the suspension the alignment improves ... but is still off.
I thought I might have installed the rearend mount bracket backwards, but such is not the case as the slightly staggered mounting holes only work one way.
Is this normal? Is there a trick to installing new strut rods?
Old Sep 7, 2012 | 06:37 PM
Alan 71's Avatar
Alan 71
Hi CW,
Yes this is normal.
If you think about the way the trailing arm and it's parts pivot you can see how the connections for the strut rods changes as the trailing arm drops.
As you lift the arm up the strut rod geometry improves and the rod installation is easier.
Good Luck!
Regards,
Alan
Old Sep 7, 2012 | 06:46 PM
Corvette Kiwi
Alan 71,
Thanks for the info.
However, even after raising up the suspension it is a tight fit as I need to heavily tweak the arm into position. Something doesn't seem entirely correct with the geometry. Maybe when the car is off the jack stands and down on the ground under its own weight the suspension will settle and the geometry will improve?!
Old Sep 7, 2012 | 07:21 PM
Mooser's Avatar
Mooser
I did mine last winter
Here's how I installed everything but part way down you'll see how I had to install the strut rods. Yes they are off-set about an inch or so, this worked nicely
http://forums.corvetteforum.com/c3-g...long-post.html
HIH
Mooser
Old Sep 9, 2012 | 03:22 PM
Corvette Kiwi
I found out what the problem was ... you can't install the strut rods when the rear leaf spring is installed. With no spring and/or shocks installed, I used a floor jack to lift up (which fixes the bogus geometry issue) and hold the rear trailing arm. At that point the strut rod slips right into place.
Then, lower the control arm down about half way, jack up the outer edge of the leaf spring, and then install the bushing/washer/bolt combo.
Old Nov 3, 2015 | 01:40 PM
Tennessee2's Avatar
Tennessee2
Cruising
I know this is an old post but thanks for the follow-up Corvette Kiwi. I raseld (Southern pronunciation of wrestled) with the strut rod installation for the better part of two hours Sunday afternoon. After reading this post yesterday, and taking Kiwi's suggestion, I removed the leaf spring bolt. Within 10 minutes I had the strut rod in with the camber bolt and shock support installed too.
To Rear strut rod problem
