overheating problem
Old Oct 9, 2012 | 01:00 PM
  #61
azguy's Avatar
azguy
Perfect thanks. It might be a day or 2 before I can get to it.
Old Nov 13, 2012 | 12:00 PM
  #62
spinadog's Avatar
spinadog
UPDATE: I solved my problem - and feel embarrassed but want to share in case I can help someone else.
I have changed all components in my cooling system as mentioned, Dewitt radiator, high-flow water pump. I also had tested my thermostat (180) and it opened when tested right at 180, no sweat. have 1/8" holes drilled in it to prevent air pockets (have none) but still had the issue of high rises in temperature at higher engine RPMs.
Well, it WAS my thermostat. I removed it and went for a 45 minute drive. Damned gauge never went about 160 or so, and NEVER MOVED. More research and I found that some people have had issues with (traditional) thermostats being forced closed at high RPM due to high water flow pumps. Recommendation is a high-flow thermostat (such as one from Moroso). Can't believe I waited 2 f&*%$ing years to check the thermostat.
I can now see that my shiny new Dewitt radiator (along with new seals etc) does an amazing job of keeping the motor very cool.
Happy camper.
Old Nov 13, 2012 | 12:51 PM
  #63
REELAV8R's Avatar
REELAV8R
Or a balanced flow thermostat. Especially if you have a high flow water pump I could see this becoming a problem. You can pick one up at Oreilly's
http://www.stewartcomponents.net/Mer...ory_Code=Therm
Old Nov 13, 2012 | 07:08 PM
  #64
Doug1's Avatar
Doug1
Originally Posted by spinadog
UPDATE: .
Well, it WAS my thermostat. I removed it and went for a 45 minute drive. Damned gauge never went about 160 or so, and NEVER MOVED. .
damnit dude, I told you! glad you got it fixed/solved
september 16th I told u, almost 2 months!
Old Nov 13, 2012 | 07:15 PM
  #65
azguy's Avatar
azguy
looks like I will have to give removing mine a try. The Vacuum worked fine so i am still stuck.
Old Nov 13, 2012 | 07:45 PM
  #66
Doug1's Avatar
Doug1
I've had a few beers and this thread is so old and kinda long, I got confused about who the OP was, yeah azguy, take it out and see.
Old Nov 13, 2012 | 08:04 PM
  #67
azguy's Avatar
azguy
well it took spinadog 2 years to get it figured out so maybe his pain will help me. I have tried everything else. So no worries Doug1 at least one of us got it figured out lol I just got home from work here in AZ so I am about to have a few beers myself.
Old Nov 13, 2012 | 08:36 PM
  #68
AirborneSilva's Avatar
AirborneSilva
Not to jack but to maybe add and well maybe get myself and answer
I had a flex fan(with no shroud), and hated it but it did keep the engine nice and cool, about 180 - 190 but I hate that damn flex fan so I bought a dual e fan setup with shroud, put them on and now like the OP at highway speeds 60 - 70 it heats up around 200 or so, but in stop and go traffic it's just fine. I do not have the foam on top of the radiator support so that's what I'm going to try next. The timing is set at initial of 12* don't know total. New motor with just over 500 miles but again with that damn flex fan that I hated (have I mentioned that ) it kept it nice and cool. Oh, I do have a 180 t stat in it too with 2 gallons of anti freeze and an aluminum radiator (not Dewitts).
thanks for any and all suggestions.
Old Nov 14, 2012 | 10:23 AM
  #69
spinadog's Avatar
spinadog
heh heh, no worries - put a smile on my face seeing your passion come through!
Old Nov 14, 2012 | 10:28 AM
  #70
spinadog's Avatar
spinadog
quite correct - I am referring to the same thing. I saw it stated both ways but the essence is to balance the pressure at both sides to prevent closure from excessive water force. So, a balanced thermostat is more apt terminology.
Old Nov 14, 2012 | 10:33 AM
  #71
spinadog's Avatar
spinadog
azguy, get a fel-pro reusable t-stat housing gasket if you don't already have one. Makes removal and replacement so easy. best of luck.
Old Nov 14, 2012 | 11:31 AM
  #72
azguy's Avatar
azguy
I will look into that. Didn't know they made those. I always spend 10 minutes scraping off my old one lol
Old Nov 14, 2012 | 08:58 PM
  #73
azguy's Avatar
azguy
The foam helped me a bit but not enough. Maybe someone else can verify but I think 200 is around operating temp for these cars. Thats what I seem to remember from reading around anyway. What temp did you have your fans set fro to come on and off? My car seems to go over 220 and into the red when it goes up. If its that low I wouldn't think you have to worry.
Old Nov 15, 2012 | 04:46 AM
  #74
AirborneSilva
thanks AZ, yeah mine is certainly lower that yours by far. I have mine set to come on right after the 180 T stat opens then they shut off at I believe 160 if I remember right. My 180 seems to be just a hair above the first mark on the temp gauge with 200 being the next mark so I'm not too sure how accurate my gauge is. I do have a mechanical gauge I can put on it to check accuracy.
The thing that has me a bit worried is that when it got to the point of being it's hottest on the highway, up to almost the "200" mark it was on a nice day of only about 82 degrees and I had only been on the highway for about 4 -5 miles cruising at 65 MPH. So what happens next summer when it's 105 plus and If I am able to get the AC going by then too, well hopefully I can get the AC going before summer
Thanks again AZ
Old Nov 15, 2012 | 07:36 AM
  #75
azguy's Avatar
azguy
Take it for a longer run and see if it goes up any higher, if it stays at or elow 200 you might just be throwing money away. That bieng said. Adding the seals bout me a good extra 10 minutes or more on overheating so if you dont have yours on I would get them and double check the reading on your gauge. Although if you didn't change your sender when you changed fans everything should still be relative to what you had before regardless of if it was accurate but never hurts to check.
Old Nov 15, 2012 | 09:58 AM
  #76
AirborneSilva
Roger that AZ, thanks!
Old Nov 15, 2012 | 10:31 AM
  #77
REELAV8R's Avatar
REELAV8R
Airbornsilva, you could try what I did before I got an aluminum radiator. I added to the air dam with a piece of that stuff that goes along the bottom of a wall as a sort of kick board, can't remember what the stuff is called. It's about 4" by 4 feet and is made of either vinyl or rubber. You can pick it up at a home improvement store. Then attach it with aluminum poprivits and stainless steel fender washers like this.
[IMG][/IMG]
It was worth 15 to 30 degrees on the temp gauge depending on the day as near as I could figure. It also had a dramatic temperature lowering effect on the a/c temps on the highway.
I also added some sheet metal behind it to stiffen it up so it would not just bend over at high speeds.
[IMG][/IMG]
To overheating problem
Old Nov 15, 2012 | 11:03 AM
  #78
AirborneSilva
Thanks REELAV8R, I'll give that a shoot, my air dam is not in the best of shape, although still functional, so if I screw it up no big deal
Old Nov 15, 2012 | 11:11 AM
  #79
REELAV8R's Avatar
REELAV8R
I found it easiest to take the air dam off and put it all together on a bench.
I have also notice that the the sheet metal does make a difference. In the center section I do not have any sheet metal reinforcement and after a drive I can see where the rubber has bent over in the middle vs the outer edges that are reinforced.
Old Nov 15, 2012 | 11:13 AM
  #80
azguy's Avatar
azguy
So if I understand correctly, you lowered your air dam by a few inches to catch more air?
