overheating problem
Old Nov 20, 2012 | 02:38 PM
  #101
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
removed due to posting twice
Old Nov 20, 2012 | 02:39 PM
  #102
chevymans 77
here is a pic of my remote oil filter and cooler for AirbornSilva:
Neal
Old Nov 20, 2012 | 06:32 PM
  #103
Doug1's Avatar
Doug1
what do the lines get hooked up to? thanks for post btw
Old Nov 20, 2012 | 06:37 PM
  #104
AirborneSilva's Avatar
AirborneSilva
Neal
thanks Neal, looks good. Where exactly is the remote filter? I think I see but am not sure
Old Nov 20, 2012 | 07:07 PM
  #105
azguy's Avatar
azguy
My car did the same thing, temps just kept climbing as the speed increased.
Oil temps would also climb with speed, as in 250* to 260* and higher.
The water temps were right behind the oil temps trailing along. I fought this for a couple years installing 3 different fan setups, AFR tuning with a wide band tuner, timing in every configuration I could come up with, vacuum advance no vacuum advance, 3 different water pumps, 3 different radiators, modifications to the nose of the car for better air flow to radiator and the only thing that brought the temps down to a manageable level was the engine oil cooler.
When I look back at the thousands of dollars spent to try and keep the engine cool and compare it to an engine oil cooler that can be bought for around $250 I got to look at it as a lesson learned.
You obviously need to make sure that all the components in the cooling system are working correctly and verify the oil temps to make sure this is your issue. If the water temps would be higher than the oil temps than I would say you don't have an oil temp issue.
I also spoke with a engineer at Hayden an he also told me to check the oil temps to see if they were the problem.
Now I'm running a 496 and I think the .060 over bore has allot to do with my temp issues.
I agree with Tom D. that each over heating issue is different from car to car but when I finally got mine fixed were I could drive the car and enjoy it I was at the end of my rope on trying to figure out what was causing the problem so when another forum member recommended installing an engine oil cooler (after verifying high oil temps) I was open for just about anything.
Today it doesn't matter what the outside temps are my car stays at T-stat setting of 180* nor does it matter how hard I drive the car.
After reading all the cooling issue threads on the forum day in and day out it sure seems as if the C3 had a marginal cooling system from the factory.
Just offering up what worked for me after endless attempts to fix mine.
It sure is great to know you can take it out for a run and not need to worry about the engine temps.
Neal
I can do short runs of up to 30 minutes or so before it gets too hot. I will definitely give the oil cooler a shot. I have noplansto switch the radiator or anything out. Its a dewitts so I doubt I can do better than them lol I just wont have money for the cooler until after the holidays. If it worked for you after the problems you described it's worth a shot.
Old Nov 20, 2012 | 10:35 PM
  #106
chevymans 77
The remote filter is mounted to the trans cross member.
I have side pipes so I ran the lines through the hole for the exhaust pipe.
the picture was taken with my phone, reason for poor quality.
If you have some time and want to see what I went through with the cooling issues read through this thread:
http://forums.corvetteforum.com/c3-t...ler-496-a.html
now near the middle of this thread I switched from a very low efficient oil cooler to the Fluidyne cooler that is pictured in this thread. Its not well documented in the thread but when I moved the cooler form the front of the car to the rear of the car I installed the Fluidyne cooler.
Neal
Old Nov 21, 2012 | 05:04 AM
  #107
AirborneSilva
thanks again Neal
Old Nov 21, 2012 | 04:32 PM
  #108
azguy's Avatar
azguy
Thats a pretty slick set up Neal
Old Nov 21, 2012 | 04:57 PM
  #109
AdamMeh's Avatar
AdamMeh
I test drove our '77 on the freeway today for a short distance - about 3 miles each way. Only the second time at steady speeds like that. The motor is pretty new (about 150 miles on it) so I know it might run a little warmer until it's broken in.
New temp sender and 180 thermostat when I put the new motor in. Stock type replacement radiator which was in the car when we purchased it last year - very clean inside and in like new condition visually. Stock type fan and clutch.
My temp gauge runs right at 200 / 210 always, until I get up to speed for a bit like I did today. Temps climb to about 220 / 230 and hold there - or at least they did for that distance.
I got out my IR gun after reading this post and took temps in several spots: upper and lower rad hoses (at both ends), thermostat housing, intake manifold, directly on the temp sending unit (drivers side head) etc. All of those temps are running 30 degrees (and more) cooler then the gauge is showing.
When I started testing, the gauge was reading it's normal 200 / 210 area. Thermostat housing shows 170 / 175, upper hose shows about the same, lower hose shows 115 / 130 depending on where I aim the gun etc.
Looks to me like this sending unit is way off. I'm wondering if that's that case with your car as well?
Also, I have foam seals on top of the radiator support (to hood), under the support across the top of radiator, and I just added another on the passenger side (down the side of the radiator). We'll see if that helps.
Adam
Old Nov 22, 2012 | 02:57 PM
  #110
azguy's Avatar
azguy
I am not sure about the others in the thread but when I tested mine they were right about where the gauge read. I have a new motor but the original temp sender. The new ones can be off like yours reads. I think it has something to do with the resistance they are set for if I understood what I read correctly
Old Nov 22, 2012 | 03:15 PM
  #111
AirborneSilva
I too have a new motor with old temp sender so I'm fairly certain that mine is accurate. While mine is not getting as warm as the rest of you guys it's still not staying as cool as it was with that flex fan, I hated that flex fan (have I mentioned that before )...
Old Nov 26, 2012 | 11:06 AM
  #112
azguy's Avatar
azguy
Why exactly did you hate your flex fan?
Old Nov 26, 2012 | 01:05 PM
  #113
AirborneSilva
Couldn't hear anything else but that damn whirring noise
Old Nov 26, 2012 | 05:28 PM
  #114
azguy's Avatar
azguy
Lol that would be a problem. I never heard my stock fan unless the hood was open
Old Nov 26, 2012 | 07:25 PM
  #115
AirborneSilva
That was all I could here, it was SOO much nicer when I ditched it, have I mentioned that I hated that damn flex fan
Old Nov 26, 2012 | 07:46 PM
  #116
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
I think it's time to close this one out, subject taken a new life
Old Nov 26, 2012 | 07:51 PM
  #117
AirborneSilva
Sorry, was just having a little light hearted moment with the OP of the thread and we are the ones after all whom are dealing with our Vettes getting a little warmer than we are comfortable with.
Didn't mean to offend anyone
To overheating problem
Old Nov 26, 2012 | 07:54 PM
  #118
AdamMeh's Avatar
AdamMeh
No offense taken here.. I was getting a good flex chuckle out of it
Old Nov 26, 2012 | 08:00 PM
  #119
AirborneSilva
Thanks Adam
Old Nov 26, 2012 | 08:58 PM
  #120
AdamMeh's Avatar
AdamMeh
Neal
That is awesome. I hope you don't mind, but I'm stealing that idea for our '77. No front plate needed here.
Adam
