What Temp. thermostat?
The 1981 & 1982 C3's had computer-controlled engine management systems. They may need a 195* stat for the system to operate properly (must reach temp above 180 or higher for the ECM to switch to open-loop operating mode).
The main reason I'm against using lower temperature thermostats, is cylinder wear. I read an article once on cylinder wear, and it stated that around 90% of wear came from startup, and an additional 10% came after startup, and before the engine reached operating temperature. It showed that there was almost no cylinder wear after the engine reached operating temperature. A lower temperature thermostat is not going to lower the operating temperature, it's going to lenghten the time it takes to get to it.
Modern cars use 195 degree thermostats. 195 is not overheating, and at that temperature your engine will experience less engine wear, and burn off more emissions. That is why I run a 195 thermostat, and I live in Austin, where the typical summer day is over 100 degrees, and I don't have any issues with overheating.
But, it will increase the amount of time it takes to reach the engines operating temperature, and thereby increase the amount of time that the engine experiences greater cylinder wear.
The engine will warm up at the same rate, regardless of thermostat.
The only difference is the target temperature the thermostat is trying to regulate the coolant at.
A 160 will heat up at the same rate as a 195 thermostat (up until 160, of course).
Elm
Elm
The operating temperature of an engine is a range. The lower end of the range is set by the thermostat, and the upper end is set by the cooling system.
The designed purpose of the thermostat is to get the engine temperature into this range, and above the bottom end as quickly as possible by restricting the flow of coolant through the cooling system until the coolant has entered the desired range.
Cylinder wear has been shown to be at 160 degrees to be twice that encountered at 180 degrees. Therefore it is desirable to set the lower end of the operating range, via the thermostat, to at least 180 degrees.
The upper end of operating range will not be changed, be the lower the bottom end is, the sooner the cooling system is engaged, and the longer it will take to get to the desired upper end of the operating temperature range.
Needless to say, that in AZ, I opted to keep the 160* stat in the engine.
P.S. That is a very interesting chart. Notice that for "performance", the engine should run cooler. For least wear, it should run a bit warmer. However, the difference in wear rates...once above 160*F...is miniscule, at best. The greatest wear is when the engine is COLD (like winter warm up's)--50*F and colder is not good for the engine. But, I bet that chart curve is drastically different with full synthetic oil in the engine. It flows better when cold and has much better lubricity and film strength than organic (dino) oil when cold.
To me, coolant temperature is just that, coolant temperature. You also have oil temperature (which for me is just as, if not more important than coolant temp), exhaust temperature and combustion temperature.
What constitutes "operating temperature"? Is it simply coolant temp and nothing else?
If everything were perfect, the 'low' and 'upper' range of the cooling system should be equal- If you have a 160 or 180 thermostat with an adequately designed cooling system, the coolant should really never exceed the temperature set by the thermostat.
Cylinder wear at cooler temperatures is a function of several things- Cold engine parts will tend to fit 'looser' than when warmed up, contributing to wear. Oil is also colder and tends to flow more slowly upon start-up (not to mention the time it takes for full pressure to develop), contributing to wear.
I'm not sure you can just make a blanket statement that running a 160 thermostat will wear your engine faster than a 180? But I've been wrong before. That's why I like this this forum, I'm always learning.
I don't claim to be an expert at thermodynamics, I'm only going by personal experience.
But I'm always willing to learn!
