Power brake conversion problem
Old Jun 2, 2002 | 05:00 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
Default Power brake conversion problem
I've installed the new booster and master on a 70, using the two lower bolts holes as the guide for the two lower booster holes, and drilled two new upper holes using the booster gasket as a template. Looking at the holes from the dash side, they appear to be in the right spots on the metal support bracket.
The problem is that bracket/pin for the booster is about 1/2" higher than the hole in the brake pedal. I'm not sure what I need to do to hook up the pedal...redrill the hole on the brake pedal or remount the booster or ???
Any help on this would be greatly appreciated.
Old Jun 3, 2002 | 11:31 AM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: Power brake conversion problem (corvgreg)
When you install power brakes the braket is 1 inch lower then the non-power brakes. The brake light switch also gets moved. It is impossible to drill new holes in the brake pedal arm without removeing the assembly and that is a whole new problem. I went from manual to power brakes and found the holes already in the fire wall.
Old Jun 3, 2002 | 07:22 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
Default Re: Power brake conversion problem (norvalwilhelm)
Norval,
Do you mean the metal bracket that the booster bolts to is 1" lower in a PB car...so that means the non-PB support bracket is unusable?
Thanks,
Greg
Old Jun 3, 2002 | 10:05 PM
LeAnn82Collector's Avatar
LeAnn82Collector
You are so smart honey! :seeya
Old Jun 4, 2002 | 12:18 AM
jwbert's Avatar
jwbert
Default Re: Power brake conversion problem (LeAnn82Collector)
You need to trade hol es on the brake pedal. The Brake rod now in the lower hole and brakelight bracket (new one for power brakes) in the upper hole. Zips or CC should have them.
:yesnod:
Old Jun 4, 2002 | 08:54 AM
norvalwilhelm
To get more leverage for manual brakes they mount the rod 1 inch higher or closer to the pivot point for the brake peddle. With power brakes the activation rod is moved down or closer to your foot by 1 inch and the brake light switch is mounted in the old hole above the new mounting hole for the power brakes.
Confussed yet? I am getting there myself.
Old Jun 4, 2002 | 03:14 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
Thanks guys...I'll check to see if I can attach the lever to the lower hole and the switch brackt to the upper hole.
To Power brake conversion problem
