Lhd->rhd
http://www.corvettesdownunder.com.au/
Lars
My 74 was converted to RHD when imported to Oz (by previous owner), if you import a LHD and it's over 25 years old
you don't need to convert it (in the state I live in-Victoria Australia).
As phil81 said the floor is smaller on the right side making the pedals a lot closer together, among other things.
Cheers,
Gav
How about telling us WHY you want to do this? If it's just to be different, why not put a Ford engine in it, etc. This can easily be removed and the car restored to original later on. But once you hack up a car to convert it to RHD, the skills of a Jedi Master will be needed to re-convert it to LHD at a later stage.
I'm also on the '67 to '72 truck forum, and a few of those guys have converted to RHD "just to be different". However, there is a ton of room under the bonnet on those things, the engines are mounted centrally in the chassis, and the dashboards are "symmetrical" and lend themselves to this kind of conversion.
However, C3 Corvettes were built with the engine moved over one inch to the right, to give the driver more leg room. The right engine mount bracket is about two inches further to the rear than the left one, and the steering box needs to share the same space as the bracket if converted to RHD. Or you can find a RHD R&P (good luck!!!)
and try to engineer that into the car.
Then there is the instrument panel and the HVAC ducting, plus the wiring loom, etc. Then you still end up with two inches LESS leg room than the LHD set-up. Of course, you could move the engine two inches to the left to compensate for this, but then the narrow transmission tunnel gets in the way. So you have to chop that up and move it.
Then there's the trans X-member: the trans mount will have to be moved, will the exhaust pipes line up with the X-member holes? I'm guessing "No".
So unless you have a very close relationship with someone with the skills of Chip Foose and a wheelbarrow full of Benjamins that you don't want, I'd look at something else to occupy your spare time.
Regards from Down Under.
aussiejohn
Reason for the conversion is that I live in Hong Kong, a RHD city. Pathetically, our authority banned the registration of LHD vehicles some 12 mths ago.
Now u guys undestand my difficulty.
Thx for the comments btw.
Your best bet is to look for a RHD car that is for sale in Australia and ask for a local Forum member to look at it for you. If the conversion has been done well, then you could import it to HK and hopefully get it registered. The shipping costs will be a fraction of what you'd spend having a conversion done.
Then you could sell your existing car to someone in OZ and maybe you won't be out of pocket too much.
Good luck and let us know what happens.
aussiejohn
so engine has to be moved a inch or so to the right.....
has little to nothing to do with driver room....that's just a slight plus....
BTW, my conversion was done without relocating the engine, however I have started to convert back to LHD for originality.
Joe
A u-joint can take (an in fact to avoid flattening the needle-bearings, should take) more than just a little angle; it doesn't matter if it's left/right, up/down, whatever, as the u-joint just knows the total angle, not the direction of the difference. Moving the drivetrain over by two inches is not going to exceed the operating-range of the u-joints (and they could be clearanced if they did face interference in the yokes).
I agree that your best bet would be to spend the money on a RHD Corvette with a decent conversion.
