Front Suspension Spreader Bar purpose/Function ?
Old Sep 26, 2012 | 12:17 PM
8valve's Avatar
8valve
Default Front Suspension Spreader Bar purpose/Function ?
Reading posts, it appears that the front suspension Spreader Bar
aids in handling, especially in hard corners.
Is there a suggestion that under hard driving conditions the frame rails at the front control arms actually move and the spreader bar stops this ?
Thanks for any insight.
8Valve
Old Sep 26, 2012 | 01:52 PM
pws69's Avatar
pws69
8Valve
They are ALWAYS moving from the flex while driving hard or soft....
Spreader Bar does wonders!!
Old Sep 26, 2012 | 05:17 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Every C3 would benefit from installing a spreader bar.
Old Sep 26, 2012 | 05:39 PM
jb78L-82's Avatar
jb78L-82
^ what they said about spreader bars!! Every C3 should have one!
Old Sep 26, 2012 | 05:48 PM
MrJlr's Avatar
MrJlr
They really make THAT big a difference ?
Old Sep 26, 2012 | 08:12 PM
Greg73convertible's Avatar
Greg73convertible
Do they push out or pull in ?
Old Sep 26, 2012 | 08:22 PM
doctorgene's Avatar
doctorgene
Yes Sir; They don't push out or pull in. They stabilize the A-arms & spring towers so they can't flex. Yes you will notice the difference, it's like a whole new front suspension set up. Of course the rest of the suspension will have to be in drive able shape. Have a great one. Gene
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
This used to be in the Corvette Forum Tech base but is gone. Still appears on CAC C3 section.
http://www.corvetteactioncenter.com/...8/025/article/
Old Sep 26, 2012 | 08:57 PM
pauldana's Avatar
pauldana
yea... what all they said.... got one.... give the c5 and 6's hell in the canyons....and that is a vital part of it...
Old Sep 27, 2012 | 01:13 AM
68thumper's Avatar
68thumper
I installed my homemade one yesterday...took about an hour and $60...I like it..
http://forums.corvetteforum.com/c3-t...eader-bar.html
Old Sep 27, 2012 | 12:59 PM
cottoneg's Avatar
cottoneg
I have a few questions
1) Does installing one change your alignment settings?
2) When getting an alignment do they have to loosen the spreader bar to get shims in and out? When they tighen the spreader bar down will the alignment change?
Thanks!
Old Sep 27, 2012 | 01:02 PM
68thumper's Avatar
68thumper
I have not checked my alignment settings since installing the bar. But I can tell you that the location of my bar does not interfere with making alignment changes. The bar is mounted away from the upper control arm bolts.
Old Sep 27, 2012 | 01:03 PM
pauldana's Avatar
pauldana
Thanks!
1. No, it keeps your alingment in tack in corners, turns and etc...
2. yes, but same bolts they loosen anyway for alignment, no difference. no.
Old Sep 27, 2012 | 01:17 PM
68thumper's Avatar
68thumper
If the bar is attached to the upper control arm bolt wouldn't you have to losen or remove the bar so as to let the upper control arm move away from the upper control arm mount? I think the bar is pushing against the control arm...no?
Old Sep 27, 2012 | 01:24 PM
pauldana's Avatar
pauldana
mine is attached by both upper A arm bolts. but those have to be loosened anyway to set alignment. this really is a non issue. your home made one may be different???
Old Sep 27, 2012 | 02:18 PM
steved400's Avatar
steved400
This bar made the biggest difference in handling in all the additions to my suspension.
After long thought and reading many post; I decided to set mine at neutral, it was the best decision to make! I already had my alignment set a little agressive and it holds it in place for both directions of movement; this is a must for every single C3.
Old Sep 27, 2012 | 02:50 PM
MrJlr's Avatar
MrJlr
OK.....well they're pretty cheap....and I run electric fans....is there a 100% bolt on kit made ?
To Front Suspension Spreader Bar purpose/Function ?
Old Sep 27, 2012 | 02:56 PM
zwede's Avatar
zwede
With electric fans the VBP bar is bolt-on.
I set mine with the front on jack stands. I figure that is pretty much the "neutral" position for the shock towers. It also makes it easy to remove - put the front on stands and just remove the through-bolt.
Old Sep 27, 2012 | 05:33 PM
steved400's Avatar
steved400
True neutral would be the car sitting as it was aligned.
Not neutral to the shock towers, but neutral to the action created by the bar to the alignment.
Old Sep 27, 2012 | 06:03 PM
TheSkunkWorks
If installed on the ground, it's a good idea to apply a small amount of preload. And, it is a perfectly acceptable practice to set camber slightly negative than desired and adjust it to spec with the spreader bar.
Figuring someone out there might be wondering while on the related topic, the factory spec measurement between upper control arm shaft supports (aka, shock towers) is 26 3/8" at the shim contact surface. That said, if one's chassis has sagged significantly below this spec, I disclaim responsibility for any mishaps should anyone try to gain too much back with the bar alone.
