3/4-1" rubber piece???
Old Sep 30, 2012 | 10:22 PM
Tom Green's Avatar
Tom Green
Default 3/4-1" rubber piece???
Another crazy question, while pulling out the carpet out of the rear compartment (passenger side) I found a piece of rubber(?) about 6"x6" just behind the window about head high. When I checked the other side no rubber piece?? Any ideas what this is for? Also, when replacing the drain hoses for the rear vents, should I extend them a little further that just even with the fender well?
Old Sep 30, 2012 | 11:34 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Tom- What year is the car and do you have a pic of the rubber part.
Old Sep 30, 2012 | 11:44 PM
Tom Green's Avatar
Tom Green
Sorry, 1972. I'll try and get a pic tomorrow
Old Oct 1, 2012 | 07:49 AM
Alan 71's Avatar
Alan 71
Hi Tom,
Perhaps you found the "lock pillar pads".
They're shown very early in the AIM, UPC1-Bolt/Weld, Sheet B9.
Regards,
Alan
Old Oct 1, 2012 | 08:58 AM
7T1vette's Avatar
7T1vette
Sound deadeners, for road noise, I believe.
Old Oct 1, 2012 | 06:37 PM
Tom Green's Avatar
Tom Green
Thanks for the replies, I think the dynamat that I'm installing should help with the noise
Old Oct 1, 2012 | 06:49 PM
oldgto's Avatar
oldgto
The drain hose has a flange on it that goes against the fender well, it`s not just a piece of hose that you can extend. Then there`s a metal piece that goes on the outside of that....
Willcox has these....
Old Oct 1, 2012 | 07:12 PM
Tom Green's Avatar
Tom Green
Thanks for the info, my car is missing both pieces. All thats left is the end of the rubber hose ending flush with the wheelwell
Old Oct 1, 2012 | 08:22 PM
oldgto's Avatar
oldgto
Note that he smaller end of the hose goes into the hole from the outside, so that the flange is in the fenderwell, then the metal piece goes over it. Not sure if that part was clear in my first post? I believe they were originally riveted on, but I hear some say they replace them with stainless steel bolt & nut, which is what I plan to do.
Old Oct 1, 2012 | 09:19 PM
0Willcox Corvette
Former Vendor
http://willcoxcorvette.com/advanced_...&keywords=hose
Use the 10 off sale code too.. Tenpercent.
Old Oct 1, 2012 | 11:19 PM
Tom Green's Avatar
Tom Green
oldgto/Willcox thanks for the tips, always appreciated!!
Old Oct 1, 2012 | 11:24 PM
Katherinejjm's Avatar
Katherinejjm
Old Oct 2, 2012 | 12:13 AM
Tom Green's Avatar
Tom Green
Yes, that's what I've got left. I guess the rivets rotted off. I can see where water off of the tires could be forced past the rubber ends and into the rear compartment
To 3/4-1" rubber piece???
