Headlights wont close
Old Oct 4, 2012 | 04:04 PM
STEELSHOT's Avatar
STEELSHOT
3rd Gear
Default Headlights wont close
Both head lights on my 1970 Stingray wont close after pulling on off the light switch, can someone tell me where to start checking? Air pressure seems fine to operate the wipers.
Old Oct 4, 2012 | 04:12 PM
MelWff's Avatar
MelWff
Did you accidentally pull down the override switch below the steering column?
Old Oct 4, 2012 | 04:55 PM
Peterbuilt's Avatar
Peterbuilt
Old Oct 4, 2012 | 06:47 PM
7T1vette's Avatar
7T1vette
[It happens....]
Old Oct 5, 2012 | 12:20 PM
STEELSHOT's Avatar
STEELSHOT
3rd Gear
Thanks , someone at valet service pulled the handle on me, now one closes and the other stays open. Any recommendations?
Old Oct 5, 2012 | 12:30 PM
Peterbuilt's Avatar
Peterbuilt
http://forums.corvetteforum.com/c3-t...tem-works.html
Old Oct 5, 2012 | 12:57 PM
harris1507's Avatar
harris1507
Check the vacuum lines on the switch maybe one came off
Old Oct 6, 2012 | 11:56 AM
78IndyPace's Avatar
78IndyPace
The problem is somewhere in the part of the system that controls and operates only the headlight that won't close: relay, actuator, and related connecting hoses.
First check the small hose into the relay. If it's not connected or is plugged, that headlight will not retract. If it IS connected and you find good vacuum at that point, then test the relay. I think the relay is most likely your problem.
Since one headlight operates normally, you can be confident that all parts common to both headlights are OK: filter, check valve, headlight switch, pull-down bypass valve, vacuum reservoir, and hoses connecting those parts. The same logic applies to the parts controlling and moving the headlight that works properly.
Old Oct 6, 2012 | 12:24 PM
Alan 71's Avatar
Alan 71
Hi SS,
Which side isn't opening?
I don't mean to confuse things .... but....
on 70-72 cars with 2 headlight relays, the RIGHT-SIDE headlight RELAY vacuum supply is T'd off the same SUPPLY (yellow hose) as the WIPER- DOOR relay. Thus a problem at the RIGHT-SIDE HEADLIGHT relay/actuator MAY be traced to the WIPER-DOOR relay.
Both, (headlight and wiper-door), relays should be checked for proper function with a vacuum pump/gauge.
Good Luck!
Regards,
Alan
Old Oct 6, 2012 | 03:39 PM
scottyp99's Avatar
scottyp99
Ummmmm..........push the handle back?
Keep the shiny side up!
Scott
To Headlights wont close
