1980 wont start
Old Oct 5, 2012 | 11:53 AM
ostateborsch's Avatar
ostateborsch
8th Gear
Default 1980 wont start
Can anyone help me? My 80 wont turn over, I changed battery tested the starter / solenoid alls good, heres the problem, I turn the key and the dash lights come on and the blower motor goes on but when I turn the key all the way it all goes dead silent no click no nothing.
Help Please
George
Old Oct 5, 2012 | 01:38 PM
speedreed8's Avatar
speedreed8
may be the neutral safety switch, try moving shifter from drive back to park, or try to start it with shifter in neutral.
Old Oct 5, 2012 | 08:39 PM
garygnu's Avatar
garygnu
check your batt ground .
Old Oct 6, 2012 | 06:21 AM
scottw's Avatar
scottw
Are you getting power to your starter? Fuseable link going to starter still good? As garygnu said, check your ground too.
Old Oct 7, 2012 | 01:41 AM
texasbaehr's Avatar
texasbaehr
the anti Theft system disables the starter when activated. Try locking and unlocking the doors with the key then try to start it. Check the fuse for the Anti theft system.
The relay for the ATS starter disable is under the console plate in front of the shifter. Mine went bad, I pulled it and jumpered the connector. system still works but starter dont get disabled.
Old Oct 17, 2012 | 11:30 AM
ostateborsch
8th Gear
Thank you I'll check it out
Old Oct 17, 2012 | 11:48 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...the anti Theft system disables the starter when activated...
Not on the 80 models. The 81s and 82s have the starter interlock.
Old Oct 31, 2012 | 02:48 PM
ostateborsch
8th Gear
you are correct thank you
Old Oct 31, 2012 | 02:49 PM
ostateborsch
8th Gear
thank you i will chk it out
To 1980 wont start
