Not on 68's. The 69-73 gas door emblem was attached with 1/4-20 machined acorn nuts. The back side of the 68 emblem has hollow stakes, or rivets, that get peened over to secure it.
To attach the emblem, use a punch, of something similar, to peen over the stakes.
Interesting. In other words, it's the same technique that's used to retain the horn emblem to the horn cap.
The 68 fuel door emblem is supposed to be staked to the fuel door. How do you do this? Or what alternate methods are there for attachment?
The 1968 emblem was riveted to the gas door unlike the 1969-1973 cars that used nuts to hold it in place.
They are not a hard job but one that will take patience. I use a hardwood cutting board, lay a cloth down and then put the emblem and door on top of it. With a drift gently brad the rivets over.
You don't want a rag that is too thick so don't fold it.. you just want something there to make sure you don't goof up the paint or the emblem chrome.
Damaging the emblem was exactly my concern. This is exactly thr info I was looking for, thanks!
I think those posts are 'spun' down...not pressed to final position. 'Spinning' causes frictional heat and softens the pins while they are pushed into position. If you just press those pins, I think they will just break off....or, at least, sustain a lot of damage. You would do better to just put some sheet metal "speed" nuts on those pins and tighten them down. No one will see underneath except you, when you fill up with fuel.
If that can be done I might just do that too. I'll get into something!
