I just purchased a 78 vette ? Not sure if it's special or now how do I decode the VIN?
When people say it's a matching number vette where are the numbers on the block located? And which numbers do I compare to the VIN to determine if it's a matching numbers car?
My VIN: 1Z87L8S422261
Sorry, delete that site from your mind. I cant figure out where they get those engine codes and the rest of the engine stuff they posted. Might be for a 77? not a 78
and at the top of the page click on 1978 corvette center for more choices.
Look on the front of the passenger side of the block and you will see a somewhat square pad which looks like this. My engine was built on 4/20 and is for a L82 4spd= CMR:
Get the suffix then look it up. This will tell you what engine you have and whether it belongs to your car. You will see a portion of your vin.
1 Chevrolet
Z Corvette
87 sport coupe
L engine code for L-48
8 model year
S plant code for St. Louis, Missouri
4 car line series code regular production 78 as opposed to Pace Car
22261 consecutive unit number
Your car is the 22261st regular production 1978 Corvette assembled. February, 1978 before Pace Car production began.
What do you mean you're not sure if the car is "special"? It's yours. That ought to make it special.
Hi GV,
The term "numbers matching" has become quite a hot topic for some people. The term means very different things to different people.
You can begin with the info you've been given so far and look for the VIN sequence stamp in 3 places.
1. The stamp pad on the engine.
2. The stamp pad on the transmission.
3. A VIN sequence stamp on the frame. It's on top of the frame rail just to the rear of the left-side rear tire. It's difficult to see with the body in place. Often you can feel an indentation were the stamp was put with your fingers which gives you a clue where to look using a small mirror.
The VIN sequence number should agree with the VIN tag riveted to the left side windshield pillar.
Good Luck!
Regards,
Alan
You could always look to see if you have the "Build Sheet" that should be glued on the top of your gas tank. Mine was on the passenger side. There is all kinds of info on that paper.
