1972 Rear Window Weatherstrip
Old Oct 17, 2012 | 10:04 AM
Tom Green's Avatar
Tom Green
Default 1972 Rear Window Weatherstrip
Fellas, any pointers for installing the rear window weather strip on my '72?
Old Oct 17, 2012 | 10:17 AM
flaco1801's Avatar
flaco1801
Dry fit it...you will probably need to cut an inch off the top... I started at the bottom and let it set...then did the sides with blue painters tape to hold in place...I used 3m black adhesive....worked out perfect..
Old Oct 17, 2012 | 02:03 PM
Mooser's Avatar
Mooser
Removable rear window
Start where the screws are, only do a little section (a foot or two)
Lots of blue painter tape (every few inches)
Then do the next bit after that's dried
I took 2 days (top one day, bottom the next (or was it the other way around?)
3M black
HIH
Mooser
Old Oct 17, 2012 | 02:31 PM
Sully1882's Avatar
Sully1882
Old Oct 17, 2012 | 03:23 PM
Alan 71's Avatar
Alan 71
Hi Tom,
It seems like not all cars had the 3 screws in each corner.
I think it's a good idea to add them if your car doesn't have them. If nothing else it makes the installation a bit easier.
Good Luck!
Regards,
Alan
Old Oct 17, 2012 | 06:49 PM
Tom Green's Avatar
Tom Green
Thanks to all for the tips, Alan appreciate the pictures!
Old Oct 22, 2012 | 04:36 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
The man is amazing.
A walking pic gallery.
Always enjoy your photo's Sir
Marshal
To 1972 Rear Window Weatherstrip
