spark problems
Old Oct 18, 2012 | 06:09 PM
377's Avatar
377
Default spark problems
i have a 73 with the covers on the plug wires and cap. when their on the to car runs with a miss. off it runs good. i run a msd 6al and crane cams pickup in stock dist im using 8mm plug wires by taylor. i want to run the car looking stock with all the covers what can i do ? thanks
Old Oct 18, 2012 | 06:43 PM
TimAT's Avatar
TimAT
Pull the covers off, get the car into a fairly dark area, and mix up a couple of drops of dish soap and water in a spray bottle. Start at the plugs and wet the wires down back to the cap. Watch for little blue sparks. I'll bet you have a bad wire or a problem with the cap. It may even be that the cover over the distributor or coil is so close it's arcing to the cover.
Old Oct 20, 2012 | 02:26 PM
377's Avatar
377
i checked the wires with soap/water and found the wires arcking at the plugs and top of the coil. the coil was sparking down the tower to the + post dont know why. but the coil and wires r about 6 months old why should their be a problem anymore help thanks
Old Nov 3, 2012 | 12:47 AM
Mariana's Avatar
Mariana
Did you remember to put silicone in the boots? And what wires are you using? personally, I suggest getting something no less that 8.5mm, get the best. To me its worth spending nearly $100 for good, thick, heat resistant wires for the spark.
Old Nov 3, 2012 | 08:45 AM
7T1vette's Avatar
7T1vette
They may be "new", but you likely bought 'junk' wiring. If you purchased based on CO$T, odds are you bought Chinese junk. That MSD box puts out a 'hot' spark; buy appropriate wires (those that are recommended by MSD).
Old Nov 3, 2012 | 03:24 PM
Mariana's Avatar
Mariana
7T1, I may have worded the post wrong, maybe not. I have all MSD myself. What I meant was you will have to pay for the quality. And know what I mean. Example....Somebody goes to Auto Zone and gets the cheaper $5 part instead of the $15 part. Another example..... Most everyone knows Dewitt has the best radiator but the price is heartbreaking so they opt for the $140 one on ebay.
Get real. China mass produces anyway, more local resources, have lower overhead and cheaper labor so there is no way Chinese products will ever out price American Made stuff. Hell, we use these forums to research what the best parts are for out cars regardless of price.
Old Nov 3, 2012 | 05:39 PM
JimmyS5600's Avatar
JimmyS5600
Active Streak: 90 Days
I agree with Mariana. Get the best part available and do the job once.
Old Nov 3, 2012 | 08:14 PM
7T1vette's Avatar
7T1vette
"Best" quality plug wires don't leak like a sieve....
To spark problems
