Oil Filter ?
Old Oct 22, 2012 | 05:54 PM
Spocc's Avatar
Spocc
Default Oil Filter ?
what oil filter is the most popular ,for an 1980 L48 ?
Pete.
Old Oct 22, 2012 | 06:50 PM
flyeri's Avatar
flyeri
You are about to get a bunch of answers. I use Wix or NAPA Gold. Same filter, less than $10.
Try this site. http://minimopar.knizefamily.net/oilfilters/index.html
Old Oct 22, 2012 | 07:44 PM
Spocc's Avatar
Spocc
thank-you
i have bookmarked the site
a friend found out the oil filter used in his v-8 was , made in China...
it failed & caused the motor to destruct
it got me thinking...
Old Oct 22, 2012 | 08:33 PM
7T1vette's Avatar
7T1vette
The "most popular" filter is probably a FRAM...because it's cheap! But, the best filter is the WIX or NAPA Gold filter.
Old Oct 22, 2012 | 08:35 PM
bluthundr's Avatar
bluthundr
Napa Gold 1794. Tall with lots of filter surface area, easy to grab to install and remove, hangs no lower than the oil pan on my car.
Old Oct 22, 2012 | 08:48 PM
Tim H's Avatar
Tim H
Fram= pig slop.
I like STP because they are blue.
Old Oct 22, 2012 | 09:18 PM
LT1driver's Avatar
LT1driver
delco, or toyota depends on which car I own.
Old Oct 22, 2012 | 09:27 PM
billcarson's Avatar
billcarson
i like fram because they are orange.i replace them after 4 months, just before the cardboard filter media starts to disintegrate.
Old Oct 22, 2012 | 09:40 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
K&N for me
Old Oct 22, 2012 | 09:48 PM
gbvette62's Avatar
gbvette62
Personally, I like to stick with the OEM Delco filter. The original filter was a Delco PF25. The current replacement Delco is a PF454.
Old Oct 23, 2012 | 12:58 AM
Vette5.5's Avatar
Vette5.5
What ever you do, make sure you get one that fits properly, as a Fram 25 and AC/Delco 25 are different. The Fram 25 physically screws on, but gasket doesn't line up. Found this out, the hard way.
Old Oct 23, 2012 | 01:17 AM
Brcmpbl's Avatar
Brcmpbl
NAPA Gold, AC PF454, or Mobil 1 for me.
Old Oct 23, 2012 | 03:28 AM
noonie's Avatar
noonie
Baldwin B279
filter area 390.78 sq in
18 micron rating
length 5-11/32 in
300 psi burst
15 gpm flow at 5 psi
20 PSID By-Pass Valve
Some of you may not like the internal bypass, but more cold oil gets filtered than the stock bypass.
Old Oct 23, 2012 | 07:02 AM
Marlin's Avatar
Marlin
I use just about anything thats not made by fram.
I have Wix filters and AutoExtra for my 73. The AE are made by Wix, think Napa Silver. You can get the AE filters cheap at Rockauto.
But Mann/Purolator, Wix, Mobil1, K&N(oil only no air), Motorcraft, are just a few good name brands for Oil filters.
Old Oct 23, 2012 | 09:45 AM
gcusmano74's Avatar
gcusmano74
I had my engine rebuilt about 5000 miles ago. The rebuilder put a short Fram filter on for the startup. After the first hour of operation, I changed the oil and filter. I cut open the Fram filter, and was surprised to find absolutely nothing on the filter paper inside. I replaced it with an AC Delco filter. After 1000 miles, I pulled the Ac filter, and cut it open. The filter paper was absolutely covered with lint from shop rags.
The Fram filter was so restrictive, the system was in bypass mode the whole time! It was not filtering anything out of the oil!
Fram filters are junk, IMHO.
You can use the AC or NAPA Gold series filters for the rear wheel drive pickup trucks. (The old AC number was PF-35. I don't remember the current number). I use the medium truck filter (NAPA 1794). It's so big it most likely will never go into bypass, and you will get 100% filtration, 100% of the time. Although it won't fit, probably, if you have headers or an oil cooler.
Old Oct 23, 2012 | 02:06 PM
Rich's'78's Avatar
Rich's'78
Default my 2c
For the Vette I use a gm PF35L. It is the truck length filter but also has a 12 micron ABSOLUTE rating - the best you are gonna get. Not cheap and not every place carries it. It was developed for racing the sbc so you can bet it flows a lot too.
BTW, I have long tube headers and the easiest way to remove the filter is to punch a hole in the bottom, let it drain and then run your punch through the bottom end of the filter, sideways. Comes off no sweat.
For my DD P/Up I use a NAPA Pro Select, which the parts guy swears is the same as the Gold, packed at half the price.
Old Oct 23, 2012 | 02:40 PM
Paul L's Avatar
Paul L
My choice. Roughly equivalent to the old Delco PF-35.
To Oil Filter ?
Old Oct 23, 2012 | 02:50 PM
REELAV8R's Avatar
REELAV8R
Wix is my preference. You can get them at Carquest if you have one in your area or a Napa gold is wix. Cheaper at Carquest.
Old Oct 23, 2012 | 05:08 PM
Tim H's Avatar
Tim H
What is the difference in the Napa Gold 1794 and the 1061?
Old Oct 23, 2012 | 05:56 PM
Clams Canino's Avatar
Clams Canino
Woa! What's a Delco PF 1218 then?
Because that's what they sold me.
-W
