Fuel tank question
Old Oct 25, 2012 | 10:09 PM
Corvette Kiwi's Avatar
Corvette Kiwi
Default Fuel tank question
I have a 1969 Corvette L-71 that I am in the midst of restoring. When I removed the fuel tank I noticed two lines: one line was the main feed line and another line had a small piece of fuel line on it that was capped off. I can't think this "capped off" is original ... so the question is, what SHOULD it be connected to?
I'm guessing that the second line tied into a smog-related charcoal canister or such, but at the rear of the car there are no factory type metal lines that give indication of a connection point for a breather or smog related setup.
Anyone have some insight?
Old Oct 25, 2012 | 11:06 PM
spdrcr29's Avatar
spdrcr29
I may be incorrect, but my .02 would be that the other line you are referring to was for the fuel return line.
Maybe the previous owner installed a different fuel pump that did not have a connection for the return line? Quite possibly this is why you found the other line to be capped off?
Old Oct 26, 2012 | 12:30 AM
bhk2's Avatar
bhk2
Old Oct 26, 2012 | 06:21 AM
7T1vette's Avatar
7T1vette
The 1969 A.I.M. will depict the "correct" setup for that tank fitting, so I would suggest that you use it as reference on whether it is capped or used.
Be aware that the 'base' car configuration is how the A.I.M. is designed, with details on optional configurations being shown within those specific options. If that fitting is capped for the base unit, you still need to check under the L-71 option sheets to see if it is used differently there.
Old Oct 26, 2012 | 07:20 AM
Garys 68's Avatar
Garys 68
The original fuel pumps had a provision for a return line that ran to the passenger side top of the tank. Pteyyu much every aftermarket pump doesn't use a return.
Old Oct 26, 2012 | 08:13 AM
Alan 71's Avatar
Alan 71
Hi CW,
I believe that in 1969, L-71 (435 hp and Holley) equipped cars used only 1 fuel line and no return line. The quadra-jet equipped cars cars used a return line.
I wonder if either the tank or engine has been changed on your car?
Old Oct 27, 2012 | 03:47 PM
loup68's Avatar
loup68
Army
As far as I know, the fuel return line always came off of the special AC fuel filter to eliminate vapor lock. Not off of the fuel pump. Lou.
Old Oct 28, 2012 | 01:15 PM
Corvette Kiwi
7T1vette,
What is A.I.M? I've heard of A.I.R. ... in other words, the air injection setup that was part of the smog system.
Alan 71,
The L-71 427 V-8 is original to my car. However, who knows if the fuel tank was changed at some point over the years.
Two questions:
1. Does anyone have info or a photo of the fuel pump used on a 1969 L-71 (in other words, did it have a port used for a return fuel line)?
2. What should be the correct numbers cast into the fuel pump for a factory-correct L-71 in 1969?
3. If a 1969 Corvette had an L-71, did it still get the regular fuel tank with a return fuel port on the upper edge (the style that was used with non-L-71 Corvettes)? If so, was it simply plugged from the factory?
Old Oct 28, 2012 | 03:29 PM
Alan 71's Avatar
Alan 71
Hi CW,
The AIM is the ASSEMBLY INSTRUCTION MANUAL. There's 1 for each year and it was used on the production line in St.Louis. In the optional equipment section you'd be able to see what all was part of, or was deleted from, the car when the L-71 option was selected.
The original L-71 fuel pump wouldn't have had an extra fitting.
Although Chevrolet did some pretty 'strange' things they would not have installed a fuel pump or fuel tank with extra fittings or nipples on a car that didn't need them and thus would have needed to have been 'blocked' off.
Regards,
Alan
This is the typical tank, passenger's side, of a car with the fuel return line. A car without return line would not have had the nipple.
Old Oct 28, 2012 | 03:58 PM
69FASTFUN's Avatar
69FASTFUN
I own an original 69 427 L71 and the fuel pump only has a line in and up to the carbs with no return. I have not checked to see if there is a line that is plugged at the tank.
Old Oct 29, 2012 | 10:47 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Corvette Kiwi
...Anyone have some insight?...
The AIM shows it. Some 69s have the return line; other engines do not use it.
...I'm guessing that the second line tied into a smog-related charcoal canister or such...
No charcoal cannister on 69s.
Old Oct 29, 2012 | 09:18 PM
LT-1 kid's Avatar
LT-1 kid
I know on my LT-1 cars, the tank has only one outlet for fuel, no provitions for a return line. canister vent on drivers side, so either you have the wrong tank or wrong motor.and 69 fuel pumps had no return, only on the fuel filter.
Old Oct 30, 2012 | 01:47 PM
69ttop's Avatar
69ttop
my '69 vett is a L46 (350 350) and it has 2 fuel lines. a 3/8 inch line from the bottom of the fuel tank to the fuel pump then up through the fuel filter to the carb. the other is a 1/4 inch fuel return line from a 1/4 inch nipple on top of the fuel filter back to the tank and connected with rubber fuel line up to a nipple on the top of the tank pass. side.
To Fuel tank question
