Correct Spark Plug gap!
Old Jun 5, 2002 | 08:31 PM
madmaxgt's Avatar
madmaxgt
Default Correct Spark Plug gap!
The manual that I have states that the Correct Spark Plug gap for my car is 0.060? Is this correct! If not what would be my optimal setting? Im replacing my plugs with AC Rapid Fire #10 Thanks!
Old Jun 5, 2002 | 08:37 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Correct Spark Plug gap! (madmaxgt)
Thats a big gap!!!:eek: I believe it's .35.... Can Someone else confirm this???
Old Jun 5, 2002 | 08:59 PM
Scott78's Avatar
Scott78
Default Re: Correct Spark Plug gap! (Mike69)
1 manual says .035 up till 74, 75-76 at .060 and 77-82 at .045 and a 2nd one says the same. Go figure I just thought .040 was it :lol: I guess I better read closer next time. I'd go the .045 which seems what they want for an HEI ignition system.
Scott
[Modified by Scott78, 7:02 PM 6/5/2002]
Old Jun 5, 2002 | 09:16 PM
Pete79L82's Avatar
Pete79L82
Rapid-Fires are pre-gapped at .045 and are recommended to be run at that.
Old Jun 5, 2002 | 09:41 PM
zwede's Avatar
zwede
When HEI was introduced in '75 GM speced .060 in a misguided attempt at lowering emissions. Not only did the emission not decrease, but they also had problems with misfires at such a big gap. They corrected it after 2 years and ever since they have speced .045-.050 for pretty much any engine.
So in short, I'd go with .045.
Old Jun 5, 2002 | 10:15 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
i would agree with the above unless you have a :mad aftermarket ignition. the hotter the coil the bigger the gap. i run my plugs at .075" and i know people with MSDs that run similar. :chevy
[Modified by clutchdust, 6:16 PM 6/5/2002]
To Correct Spark Plug gap!
