Valve Covers reversed?
Old Oct 29, 2012 | 04:48 PM
dbartol1's Avatar
dbartol1
Default Valve Covers reversed?
Hello,
Does it matter if the valve covers are reversed so that the oil cap/fill is on the opposite side of the engine? I have a 1979 L82 350cc. My oil cap is on the passenger side. I notice other cars have theirs on the driverside. Is mine incorrect? Does it matter?
thanks
Old Oct 29, 2012 | 04:52 PM
7T1vette's Avatar
7T1vette
It doesn't matter...as long as the baffles do not interfere with the rocker arms/nuts and they seal at the rails.
Old Oct 29, 2012 | 06:42 PM
dbartol1's Avatar
dbartol1
Good. Thanks
Old Oct 29, 2012 | 08:54 PM
lars's Avatar
lars
If you're running the stock PCV system, it does matter: GM designed the PCV system so that the valve is in the driver's side cover and the breather is on the passenger side very intentionally. It has to do with crankshaft direction of rotation and the natural flow of crankcase gasses within the engine (Duke Williams wrote an excellent description of the system some time ago). Although it does not matter which valve cover has the oil fill cap on it, you should keep the PCV on the driver's side and the breather on the passenger side in order for the PCV system to operate most effectively.
Lars
Old Oct 29, 2012 | 09:08 PM
7T3C3TTZ07's Avatar
7T3C3TTZ07
Default Probably Doesn't Matter
Originally Posted by lars
If you're running the stock PCV system, it does matter: Lars
Lars is correct but I think the question is related only to which side the oil filler cap is on. On my 1970 and 1973 there is a grommet on both valve covers in the same relative location. The location of the oil filler is near the dip stick on the driver's side rear on 1970 and 1973. The PVC is is on driver's side forward. The other grommet (passenger side rear) is a breather (air inlet to balance the PVC) that is connected to the air cleaner base. The grommets are the same size. If the A/C compressor is not installed, the passenger side forward is an easier place to access the oil filler for sure.
Old Oct 30, 2012 | 06:53 PM
dbartol1's Avatar
dbartol1
As soon as I figure out how to post pics Ill show you what I have. I think its wrong.
Old Oct 30, 2012 | 08:54 PM
dbartol1's Avatar
dbartol1
Old Oct 30, 2012 | 09:47 PM
'75's Avatar
'75
http://forums.corvetteforum.com/c3-p...tep-guide.html
Old Oct 31, 2012 | 05:05 PM
dbartol1's Avatar
dbartol1
Old Oct 31, 2012 | 05:16 PM
dbartol1's Avatar
dbartol1
Photobucket has changed since that pic instructional post was made. There is no IMG box to click on, or at least I can't find it. I see Email, Instant Message, HTML and slideshow, but no IMG.
Is all this really the best system to post pics? Seems other sites allow simple drag and drop. Thanks anyway.
Old Oct 31, 2012 | 09:57 PM
texas jim's Avatar
texas jim
Lars
Excellent Comment! Thank you f/ this comment. It makes all the sense in the world, just logical, that's all.
Old Oct 31, 2012 | 11:36 PM
7T1vette's Avatar
7T1vette
In Photobucket, click on the image of the gear in the upper right corner of the photo you want to post. That will display the various filetypes that can be transferred. Go to the last one (IMG) and click on it; that will 'copy' that [IMG] photo file to your clipboard. Now, switch to the CF page, put the cursor in the message box where you want to locate that file and hit CTRL-V to 'paste' it in that post. Done deal.
BTW, the PCV valve will work on either side (air cleaner vent pipe fed to the other cover); but it will work better if the PCV is located on the driver's-side cover.
Old Nov 1, 2012 | 01:34 PM
redman76's Avatar
redman76
St. Jude Donor '09
Just to clarify, after you click on gear, select "Get media links" and then you'll see the various options.
Old Nov 1, 2012 | 05:32 PM
scottyp99's Avatar
scottyp99
How much better? Because I've run it both ways and haven't noticed any difference at all. That doesn't mean there is no difference, just not one that I have been able to notice. The way the vacuum tubes are arranged on a Holley 1850 just make it a lot easier to run the PCV backwards.
Keep the shiny side up!
Scott
Old Nov 1, 2012 | 06:32 PM
7T1vette's Avatar
7T1vette
I think you would have to have the instrumentation and test cells that GM had in order to measure the difference. But, Lars is correct; it is supposed to work a bit better with the PCV valve in the left-side cover.
Old Nov 11, 2012 | 09:57 AM
surfertom's Avatar
surfertom
Default covers
thinking about running an old set of holley covers on my 350. the left side has a provision for the pvc and a breather that twists off and is the the oil filler. the right has no holes at all. although there is a spot to drill out. why does it matter which side the breather is on? don't want to drill if its not needed.
Old Nov 11, 2012 | 11:21 AM
mds3013's Avatar
mds3013
With PCV and breather on the same side, the crankcase gasses are not removed effectively. PCV sucks out gases but short cycles through the breather rather than drawing the gases out from the pan. The fresh air inlet should be one side of the engine and the PCV should be on the other. Ck. LARS' post above for ideal configuration. mike...
To Valve Covers reversed?
Old Nov 11, 2012 | 11:24 AM
surfertom's Avatar
surfertom
Default covers
thanks for the response. i'll drill the other cover , will it matter if i have 2 breathers 1 on each side? i guess i could drill the one and put the pvc in it and run on the left side. but that would leave the right side with a breather and a grommet for ?
Old Nov 11, 2012 | 11:25 AM
7T1vette's Avatar
7T1vette
The crankshaft rotates in one direction. That rotation creates some turbulence in the space inside the engine. And that causes pressure differentials throughout that space. Apparently, the higher pressure is on the driver's side of that engine block, so putting the PCV valve in the left valve cover will take advantage of a slight increase in airflow through the valve. The effect is small and the difference in PCV function on the basis of one vehicle is insignificant.
Put the [dang] PCV valve on either cover; it will work fine.
Old Nov 11, 2012 | 12:01 PM
scottyp99's Avatar
scottyp99
Yeah, the pressure generated in the crankcase has to go up through the lifter valley to get to the valve covers anyway, so I don't see how it could make a whole lot of difference either way. Way back when PCV was first introduced, the PCV valve was on the front of the intake manifold, and the air inlet was at the back, that's why you see old valve covers with no holes in them for any of that stuff. Moving it to the valve covers may have just been a cheaper way to do it, hard to say for sure, I'm not an engineer or anything.
It may make a difference if you have a breather on both sides, the PCV system will draw air through the path of least resistance. It should be set up in such a way that the only air inlet is on the other side of the engine. It shouldn't be hard to find a plug that will fill the extra hole on the valve cover with the PCV valve.
Scott
