3" Exhaust Options
Old Oct 29, 2012 | 09:38 PM
Hans4real's Avatar
Hans4real
Default 3" Exhaust Options
Are there any ready to install 3" mandrel systems for the early C3s? I've seen the 2.5 systems but would like to go to 3" with my LS5 now at 468 CID.
Also, Flowmaster makes a 3" kit, with 16 in total, pre-bent pipes that are mandrel bent and supposed to have enough parts to match pipes up for a complete system minus the exhaust cans. Anyone with experience with making this kit a reality for install?
Old Oct 29, 2012 | 10:27 PM
gkull's Avatar
gkull
I have a three inch system. But what you have to do is think about a custom tranny cross member. You need a CM that has the exhaust pass under.
My ex come straight back from the header collectors
Old Oct 30, 2012 | 12:18 AM
gve's Avatar
gve
I emailed Pypes yesterday they make a 2 1/2" system with X pipe, I asked if they can make the same system in 3". I'm waiting for a response, If I hear anything I will post it here.
Old Oct 30, 2012 | 12:41 AM
PhotoVette1's Avatar
PhotoVette1
What do you need 3" for? Remember, in dual exhaust, it's like a 4 cylinder--on each side.
Old Oct 30, 2012 | 08:33 AM
7T1vette's Avatar
7T1vette
Bigger is ALWAYS better!
[Isn't it?]
Old Oct 30, 2012 | 09:09 AM
Hans4real's Avatar
Hans4real
I'm not completely sure I do need a 3 inch. Not sure what the flow difference is between the 2 1/2 and 3 and where the big advantage would be in the power band. It's a street driver weekend Vette but if I'm going to make the change I want to do it right the first time.
Old Oct 30, 2012 | 09:36 AM
CWerner's Avatar
CWerner
I think that Magnaflow makes a 2 1/2" stainless steel with x-pipe and mufflers. It might also come in a 3" version.
I was looking at this yesterday. Part numbers are 16840 or 16842. The price was about $800.
Old Oct 30, 2012 | 10:45 AM
PhotoVette1
I have 2 1/2". It took some careful work to line it up nice through the transmission crossover. Next time I'll do 2" with an X pipe.
Old Oct 30, 2012 | 11:24 AM
gkull's Avatar
gkull
I was trying to find this old article from some car rag doing the exhaust shoot out. They had two bigger ci small block cars. One with @400 RWHP and one with just over 500 RWHP. When running a baseline 2.5 inch true dual exhaust with some turbo muflers. Identical 1 3/4 long tube Hooker S/C headers.
Then they installed an x-pipe on the 2.5 inch and the 400 rwhp gained some small %, but the 500 hp had a greater %.
Then they had a shop do a nice looking 3 inch system and again they both gained hp, but they made some statement that the 500 rwhp showed it was going lean on the O2 sensors. Then they went with the 3 inch and X-Pipe and rejetted each engine and lowered the total timing by 2 degrees. Each motor made the most HP with the big 3 inch and x-pipe.
The conclusion was that as HP went up so did the need for the least restrictive exhaust.
The 400 hp was some kind of a H-roller 383 and the 500 hp was an H-roller 427 SBC
Old Oct 30, 2012 | 01:23 PM
pauldana's Avatar
pauldana
my boys fabbed me up a 2 3/4" with X-pipe system..... 3" is to big imho do to dragging the pipes on every bump.... and i wanted an increase over 2.5"...... so I want 2.75" good fit without having to deal with 3"..... there are a lot of new cars being built with 2.75"... but no one makes a 2.75 for our cars.....
(BTW, about a 550hp engine, 383 pulling 6500-7000 RPM)
Old Oct 30, 2012 | 03:26 PM
C3 Stroker's Avatar
C3 Stroker
If you have around 500 HP or more, you will benefit from 3" pipes.....more horsepower and torque throughout the power band. Just remember they will hang lower than the 2½". No one makes a ready made system for C3s. They are all custom made. I have a 3" system with Magnaflow mufflers, and yes they fit through the crossmember. Just be careful to route them around the trans pan for access (mine is an automatic)
Hear them.....
Old Oct 30, 2012 | 05:46 PM
gkull's Avatar
gkull
My exhaust is not the lowest point under the car.
Old Oct 30, 2012 | 11:37 PM
Ray Y's Avatar
Ray Y
I disagree, 3" will fit thru the OEM frame opening. Mine does just fine on the '70, it doesn't hit or rattle and with the use of a combination of flange & band clamps removes easily in minutes. It helps my 555 cu in breathe.
Old Oct 30, 2012 | 11:39 PM
pauldana's Avatar
pauldana
the exhaust i modeled after with my 2.75"
Old Oct 31, 2012 | 01:00 AM
gkull's Avatar
gkull
I was going to install a rear end and manual tranny cooler. I just can't imagine wanting to run hot pipes so close to a tranny and the extra bends to shoot through little x-member holes.
Then for a tranny or exhaust removal you are dealing with pipes through the x-member. Or as the pictures show a highley complicated multipipe with lots of clamps for connections
Old Oct 31, 2012 | 01:10 PM
Hans4real's Avatar
Hans4real
I appreciate that option of doing a 2.75 vs. 3". Sounds like a perfect blend of flow and function. I've not seen any kits or option with that size and I want to stay with the mandrel bens because of the size reduction at the bending point. I have a 2.5 on mine now but at the bends it looks like a 2" not even close to 2.5.
Did you go with 3" in and out mufflers?
Old Oct 31, 2012 | 01:24 PM
pauldana's Avatar
pauldana
I purchased pre-bent mandrel 2.75" bends in various angles, the boys are very good at fabrication...the 3" Borla mufflers are sitting on he floor (the reason for no show-off pictures yet ) .... when they did the system, they were not here yet... so my sons put in the 2.5" Borlas back on...have not had time to finish...
To 3" Exhaust Options
Old Oct 31, 2012 | 01:25 PM
Hans4real's Avatar
Hans4real
System looks great for performance. Do you feel the X pipe is a critical part of the system? And did they custom fab that piece or can they be purchased ready to bolt up?
Old Oct 31, 2012 | 02:30 PM
v2racing's Avatar
v2racing
I always look for the most economical way to do projects but still maintain quality and performance. When I built my 3" X pipe exhaust, after much research, I bought all the pieces to build it from Summit. I figured out what I needed for mandrel bends and bought their part number SUM-642130 X pipe kit. The inside of the X needs a little cleanup with a grinder, but it all fit together well and made a very nice setup. I used a BTO trans support/cross-member and it gives plenty of room to run the 3" under. The X is directly behind the tranny. The whole system is welded together front to back and will drop off the car in one piece. It only takes about 5 minutes to drop the whole exhaust.
I'll see if I can't get a photo of the system. It's off the car right now.
Old Oct 31, 2012 | 11:26 PM
Ray Y's Avatar
Ray Y
I definitely think the x-pipe improves the performance, and you are correct the mandrel bent pipe is the way to go in order to eliminate the restrictions at the bends. My X-pipe was from Magnaflow & is 3"x13 1/2" (#10782). Magnaflow mufflers #11229.
