Frankenengine
Old Oct 30, 2012 | 06:41 PM
Zorro O's Avatar
Zorro O
Default Frankenengine
I Have a 1979 C3 running a 1986 L98 TPI engine with aluminum heads, I do not trust the bottom end on the L98. I also have a GM crate engine 10066036 with bad heads, but a good bottom end, 160 compression on all eight cylinders. Would putting my aluminum heads, TPI fuel system, and computer controlled HEI, on the crate engine work? I imagine my compression ratio would be a lot higher. Would the cam work? Will my 700R4 bolt to it? Would this setup be good, bad, or ugly? The car will be used as a cruiser.
This seems to be the motor I have.
GM Goodwrench 350ci/260HP Engine & Packages
This universal 350ci engine uses a brand new block and can be used as a replacement for most GM vehicles from 1973-85. It produces 260 HP and 350 ft/lbs torque with a 4-bbl carb and headers. It can be used as a replacement or as a retrofit into almost any vehicle. This new 350 crate engine comes with a GM warranty and is covered for 3 years or 100,000 miles in applicable GM vehicles only. JEGS has the GM Goodwrench Chevy 350 for sale at a great price!
Specifications
4-bolt main with 2-piece rear main seal
Cast iron crankshaft
LT1/LT4 powdered metal connecting rods
Cast pistons (dished)
Hydraulic flat tappet cam (.383''/.401'' and 112° lobe separation)
Cast iron cylinder heads with 76cc chambers
8.5:1 compression ratio
Block is compatible with left or right side oil dipstick (Requires Plug for Unused Side - Plugs are Included)
4-quart oil pan
Timing tabs for a 6-3/4'' or an 8'' balancer
Recommended spark plug: Accel #111-0574-4 or any spark plug with 14mm .460'' reach, 5/8'' hex, tapered seat, projected tip
Zorro.
Old Nov 1, 2012 | 06:09 PM
ZZ71S's Avatar
ZZ71S
I put some L98 zz4 heads with a .028 head gasket on this engine gives you about 10 to 1 ish compression.I used a carb I dont know about your fuel inj I think it work with a fuel inj friendly cam
Old Nov 1, 2012 | 07:31 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Will work fine but I would upgrade the cam to match your new compression.
Old Nov 2, 2012 | 12:59 AM
Zorro O's Avatar
Zorro O
Thanks guys. I guess I will start learning about fuel injection cams.
Zorro
To Frankenengine
