If you bought 100% cork gaskets, the ones you have are old and dried out....they've shrunk. You can put them in water for an hour and they will probably go back to the right size. If you do that, don't do more than snug the bolts down until the water evaporates back out. And, you won't be able to put any sealant on them when damp. Cork gaskets should be packaged in an air-tight Vac-u-Pak where they can't dry out. Many are; some are not.
The better option is to buy composition gaskets made of a cork and synthetic rubber mixture. Those seal much better (as is) and don't tend to shrink nearly as much. They also don't need sealant, except in difficult cases where the mating surfaces are rough or wavy.
The best choice is to buy best quality Fel-Pro gaskets which you can install and forget. (But, I'm sure there will be an "exception" out there. There always is.)
I agree buy the best.
My old cork compound gaskets fit fine, they just tore.
It's the new gaskets that are to short.
