Need a measurement please
Old Nov 12, 2012 | 10:38 PM
foundvettelifeisgood's Avatar
Default Need a measurement please
A prior owner glassed in the rear valance. I need to locate the exact correct opening for the rear exhaust. Would like a measurement from inside edge of right pipe opening to inside edge of left opening. Also would appreciate outside edge to outside edge measurements.
Would like more than one helper here, since I'd like to measure twice or more and cut once.
Old Nov 13, 2012 | 07:46 AM
Alan 71's Avatar
Alan 71
Hi f,
Is your car a 68-69 or 70-72? I believe that dimension is different for each group.
I think in any case I would begin by stripping off the paint and then scraping off what ever filler or glass was used until the original seam can be seen.
Regards,
Alan
Old Nov 13, 2012 | 08:09 AM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
You may want to drop the spare tire and cover and take a look from the "ugly" side. Sometimes there is a very defined bondo line on the inside that will make the job a lot easier to assess.
Rob
Old Nov 13, 2012 | 10:47 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by MrForce
...You may want to drop the spare tire and cover...
Not really necessary to drop the spare just to take a look. Crawl under and you are likely to see where the PO fiberglassed over the stock exhaust openings. Corrner of each fender and each corner of the valance panel.
Old Nov 13, 2012 | 05:30 PM
It's a 69. I've looked from behind and would still very much appreciate a measurement. The vertical seam itself will not tell me all I need to know.
Old Nov 13, 2012 | 05:58 PM
Alan 71's Avatar
Alan 71
Hi f,
Sorry, I can only help with the 70-72 measurement.
Regards,
Alan
Old Nov 13, 2012 | 07:25 PM
mrmaxxman's Avatar
mrmaxxman
my 68 measures 39" inside to inside, and 47.5" inches, and the width of each cut out is 4.25"
Old Nov 15, 2012 | 05:26 AM
Thanks for the effort. Much appreciated.
To Need a measurement please
