Ordering my Cam then Another Choice??
lol, so do I! got it cheap from my brother who upgraded to the Cleveland "some thing or other" (titanium head i think)haha, I've broken a few clubs myself....
St. Jude Donor '08-'09
Opinons are like you know what, everyone has one. Your opinion is yours, back it up with some technical data and I will lean one way or the other. Just saying something doesn't make it true. I'm going to shorten the intellectual BS ( definition: where something sounds like it makes sense and I being a brilliant person I am will go along with it without testing it for myself, collecting data and coming up with the correct answer ) and just call IBS
I have been building engines since the early 70's. Have I built some duds ( you betcha
) but most if not all were cleared up buy changing parts to the correct ones and tuning. I now build 600+HP small blocks that you can get it and not have clue as to how much power is under your right foot, until you try it. I build them so they don't overheat, they start easy and you can toll around town all day in 90deg temp. Then without shutting it off you can go directly to the staging lanes of a dragstrip and beat about anyone that turned up that night
I have the XE262H cam in my 383. When I changed from 1.5 to 1.6 rockers (all 16), I didn't see any change in idle quality, and I didn't expect to. Duration and overlap affect idle, not lift, and they are not affected by changing rockers. On the performance side, I believe the 1.6s took about a tenth off my 1/4 times.
On my cars, changing the rocker ratio changes duration and overlap and lift, even LSA. So i was expecting to re-set idle mixture and rpm. Set idle back to 550, lope is back, now and then. Graph the valve 1.5vs1.6 and you will see it is not just lift!
BK,
i've told several guys to look up your posts to see how good a 383 can run with a small cam. I would not expect a 383 to be over-cammed w/xe262, but my 355 exhaust was with 1.6.
All set to order my cam, an XE268H was my final choice. I have Edelbrock E-Street heads, Performer Intake, Hollly 4175 carb, Supercomp Header, 200r4 trans w/2400 stall (stall still to be ordered) and 3.70 rear gear. All on or going on a 76 L82, stock bottom end, new rings and bearings less then 5000 miles ago. Then another forum member suggested I get a XE262H with 1.6 rocker on the intake side only - said it was worth 10HP. Any thoughts before I place my order?
Get the XE268H. You will be more then happy with it.
Check this out. http://www.speedtalk.com/forum/viewtopic.php?p=175557
udharold is the guy who designed the Voodoo cams for Holley which changed to Lunati. Looks like he is still designing cams but does not work for a major cam company. He puts his phone number in the post, you can call the guy who designed the cams. He may even custom design you one to work with your combo.
My next cam will probably be the 60102 also. But this is interesting.
Here is his complete bio. http://www.hotrodders.com/forum/luna...ts-157971.html
A history of cam designers. http://www.harveycrane.com/founders....mps_And_Grinds
Wow, Harold Brookshire, designed cams for comp and lunati and you can call him. I just love the internet.
Simple and true.
I thought the xe262h was a little over sized for a mild 350 with 3.08 rear gear until I put a 2400 rpm stall behind it. With 1.6 ratio roller rockers on both intake and exhaust it actually ran pretty fair.
There is no way you are still reading this post.
But if you are, I called Edelbrock today and Lunati. It looks like your E-streets and my Performers have the same springs #5767 (specs on pg 168 of the 2012 catalog). FWIW the tech at Lunati said that with those springs you could run either the 60102 or the 60103 Voodoo cam without a problem.
So are you going to try 1.5 on the exhaust? Driving off on a cold start, no choke,w/1.6E i had to shift to N at the 1st corner stop. NOW W/1.5E it was running so nice i left it in D. It really likes less lift/duration on the Ex!
