Distributor question
Old Nov 14, 2012 | 12:22 PM
diehrd's Avatar
diehrd
Default Distributor question
How can I know if the gear on my HEI Distributor is a steel gear or a melonized gear
( spelling may be off on that last gear !!)
Old Nov 14, 2012 | 03:12 PM
MelWff's Avatar
MelWff
You have to specifiy who the manufacturer is of your HEI distributor both GM and many aftermarket companies make them. Are you intending to use a roller cam?
Old Nov 14, 2012 | 03:33 PM
diehrd's Avatar
diehrd
I do have a roller cam .. Not sure of the brand and have looked on line about the gears only to find out there are 3 metal types for the gears but have not found out how to tell them apart. ( brass may be an obvious )
Old Nov 14, 2012 | 09:12 PM
loup68's Avatar
loup68
Army
GM performance parts sells the gear separately.
Old Nov 15, 2012 | 08:28 AM
diehrd's Avatar
diehrd
Thanks loup68 ... I am pretty sure the gears can be bought anywhere But how does one tell visually or otherwise if the gear is steel or melonized ?????
Old Nov 15, 2012 | 10:27 AM
loup68's Avatar
loup68
Army
I bought a DUI tach drive distributor and had their gear replaced with a new GM one . I think the gear was about $16 dollars. Why take the chance of ruining your cam? I do not think it would be easy to tell what the gear is. Lou.
To Distributor question
