Timing problem
Old Nov 16, 2012 | 08:55 PM
FatCat's Avatar
FatCat
Default Timing problem
Hey guys! Here is the issue... I adjusted my timing according to the Lars timing docs and was having a detination problem. I emailed Lars and he told me to do a TDC test and here is the results. What do I do from here? It would apper that the balancer has slipped.
Any suggestions or input is greatly appreciated.
Old Nov 16, 2012 | 08:59 PM
johnt365's Avatar
johnt365
If you dont want to replace the balancer and you are positive that is your new tdc, you could make a new mark with a dab of liquid paper at the zero and use that as your mark.
Old Nov 16, 2012 | 09:01 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Yup, in the short run that's your simplest solution.
In the long run you need to replace the balancer.
Old Nov 16, 2012 | 09:03 PM
FatCat's Avatar
FatCat
Here is how I arrived at it.... I am working alone for the most part. I hook a compression test guage up to #1 and hand cranked until the needle moved up. I then put a long piece of wire in the plug hole and hand cranked until I had the piston at it's highest point, moving back and forth to verify.
76Vett's Avatar
76Vett
If your balancer has slipped/moved, it will probably slip/move again. The only sure way to fix is to replace.
Old Nov 16, 2012 | 09:05 PM
FatCat's Avatar
FatCat
Can you tell me how difficult this would be for a novis?
Old Nov 16, 2012 | 09:06 PM
johnt365's Avatar
johnt365
but it just has to stay put long enough to time the motor.
How about remark the balancer and see how it runs. See if you can get it set to 12-16* or whatever you need to get you to 36* or so. Drive it around for a bit and note the difference in performance. Then you can decide if you want to tackle that project.
PS. you know, once you have the balancer off, the cam is just behind that timing cover. I'm just sayin...
Old Nov 16, 2012 | 09:13 PM
FatCat's Avatar
FatCat
So if I am at 34* 2600 RPM's with the original mark, any know what it is really at?
Old Nov 16, 2012 | 09:16 PM
FatCat's Avatar
FatCat
My goal has been to get this car running good and then pull the engine to clean, paint, new cam ect this winter.
Old Nov 16, 2012 | 09:20 PM
johnt365's Avatar
johnt365
Its not that easy. It looks like you are 10* off. You need to know two pieces of information.
1. How much advance do your mechanical advance weights pull in?
2. At what rpm is the mechanical advance "all in".
If you were all in at 2600 then you would be at about 24* and if your mechanical pulls 20* then you are at base time of 4*. Lots of Ifs there.
Do the balancer when you do your cam. For now, I would remark the balancer and see what you get. Do you have HEI? Lars recommends a kit by Mr. Gasket 928g. Start with the lightest springs. Then, wrap a rubber band around the weights so that they do not open and set your base timing. You really need a dial timing light. Remove the rubber band. Lets say you set the timing at 12* base. Then free the weights and rev the motor and see what the highest reading is and note the rpm. If it reads 32* then you know you have a 20* mechanical advance. I'm just throwing numbers out but you get the picture.
Old Nov 16, 2012 | 09:37 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
My advice would be the same as the above.. If the balance slipped it will do it again and eventually come off. In this process it could take out neat things like the fan shroud, fan blades, radiator.. So get it off there.
How hard it is.. it's really not all things considered.
There is really no way to determine your timing with a balancer that is moving. If you make a new reference line on the balancer who is to say it won't move when you start the engine the next time.
If you are trying to just get the car running I suggest you set it at high vacuum for now.. until you can get that balancer off the car.
IMHO,
Willcox
Old Nov 16, 2012 | 09:41 PM
johnt365's Avatar
johnt365
Replace it, it's already winter enough. The underlying topic here is - what cam are you gonna use?!?!?!
Old Nov 16, 2012 | 09:55 PM
FatCat's Avatar
FatCat
A forum member sent me a Elgin Pro Stock e-923-p cam I am going to put in.
I have reset and going for a quick drive BRB!
Old Nov 16, 2012 | 10:05 PM
johnt365's Avatar
johnt365
Oh yeah I saw that. How'd the ride go?
Old Nov 16, 2012 | 10:11 PM
FatCat's Avatar
FatCat
Well, I still have a rattle in the engine under a load. I will continue to retard it until it stops. Man! I have so many issues with this thing. Falls on its face at cruising speeds. Vibrations in my console and something in the front right wheel sounds like it is about to come apart under a load. Hahaha boy I sure love her though!
Old Nov 16, 2012 | 11:28 PM
0Willcox Corvette
Former Vendor
Use a vacuum gauge and set it at High vacuum.... Won't cure the vibrations.. but it is the most optimum way if you do not have a timing tab or a good balancer.
Old Nov 16, 2012 | 11:47 PM
FatCat's Avatar
FatCat
Can you give me an idea where I can get a high vacuum gauge and how it works? Thx!
To Timing problem
Old Nov 17, 2012 | 01:38 AM
7T1vette's Avatar
7T1vette
You can buy a vacuum gauge from about any car parts store. They are not expensive. You just want to "T" it into the vacuum line coming off the intake manifold. When the car is warmed up and at idle, very slowly move the distributor...either direction...until you locate the point where vacuum level is highest (max vacuum at idle). That's the spot Willcox was referring to.
That will not be the same setting as Lars' paper describes. But, it will allow the engine to be set well enough for you to drive the car and see if you still have detonation (or not) and allow you to run the vehicle to see if the timing reading stays at the same mark from day to day.
You should use the light to read timing when MAX vacuum reading occurs. Then read timing when the dist vacuum can line is removed (and plugged) and also when it is connected. If the readings don't differ, then your advance can on the distributor is bad. [BTW, you did remove that advance can line and plug it when you read the timing at idle, didn't you?]
Old Nov 17, 2012 | 01:48 PM
lars's Avatar
lars
Your balancer has slipped, as we predicted in our e-mails. The next thing the balancer will do is come apart. I've seen it happen several times, and when it comes apart, it will rip off your fan shroud, cut the water pump right off the front of your block, put holes through your hood, and, if you're timing the engine when it happens, it will take your head off.
Replace it.
Then, time the engine.
Lars
Old Nov 17, 2012 | 02:34 PM
drwet's Avatar
drwet
Replace it.
Lars
Replace it. But if you're not going to replace it its easy to figure out the timing. You're at 44 degrees (34+10) which explains the detonation. You could set the timing at 24 deg and be OK, at least until the balancer grenades.
