damnit...help
Old Jun 8, 2002 | 04:20 PM
OatBoy's Avatar
OatBoy
Default damnit...help
i just replaced the ignition on a 350 with a real nice msd distributor and ignition coil. Now the motherkisser wont run no matter what i do, help
Old Jun 8, 2002 | 05:15 PM
trw's Avatar
trw
Default Re: damnit...help (OatBoy)
Oatboy,
We need more info. Are you getting spark?
Terry
Old Jun 8, 2002 | 05:26 PM
OatBoy's Avatar
OatBoy
Default Re: damnit...help (trw)
no im not
Old Jun 8, 2002 | 05:28 PM
1979toy's Avatar
1979toy
Are you getting 12 or more volts to the hot lead to the dist.?
Old Jun 8, 2002 | 06:41 PM
killain's Avatar
killain
Oldtimer
First see if you have any juice to the dist, then check that the no.1 cyl is tdc and that the roter is pointed at no.1 lug on the distributor, once that is OK, you should have some kind of reaction in the spark department? You need to give a little more in details?
Old Jun 8, 2002 | 06:49 PM
Darkness's Avatar
Darkness
Default Re: damnit...help (killain)
Forget what you heard here just see if you have power at the coil, take the coil to dist cable and rub it in the engine while turning it. If you don't have any power at the coil then see if you have power into the coil either on the + side and on the - side. This later one is the one that comes form the dist points or mag, just see if it is working right. If all of this is working then to problem is your coil and for this try to check it out with the old one.
Just keep us on top of the problem and you'll be fine.
Paul
Old Jun 8, 2002 | 07:01 PM
OatBoy's Avatar
OatBoy
Default Re: damnit...help (inferno-vette)
thanks, im tending to think its a coil problem at this point. also i'm having a bitch of a time getting tdc, can u give me any tips? i cant seem to turn it manually
To damnit...help
