L82 upgrade thread
Old Dec 7, 2012 | 01:59 PM
DucatiDon's Avatar
DucatiDon
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
35k.
Old Dec 7, 2012 | 02:37 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Great choice of upgrade parts. You are doing exactly what I would have recommended to you if you posted a thread questioning what parts to upgrade with.
Old Dec 7, 2012 | 02:43 PM
DucatiDon's Avatar
DucatiDon
I did a lot of research. This forum was great help.
Im now struggling to get the radiator out. Not a one man job apparently.
Old Dec 7, 2012 | 04:31 PM
DucatiDon's Avatar
DucatiDon
Progress stalled....so Ill take pics and have a drink!
Old Dec 7, 2012 | 09:21 PM
DucatiDon's Avatar
DucatiDon
Cam is in.
Took two people to juggle the radiator and shroud.
Had to remove the hood to get the AC radiator to move enough for the cam to clear.
Had to remove the upper (straight) transmission cooler hardline and fitting from the radiator to clear the A-arm.
Also had to loosen the fitting on the Ac radiator to get enough wiggle room.
PITA
Old Dec 8, 2012 | 09:23 PM
DucatiDon's Avatar
DucatiDon
I Installed a Lunati cam button behind the stock cover and had right at .005 end play. The short water pump should prevent much more than that due to flex, so I should be fine.
Timing chain, timing cover, oil pan and new oil pump are done.
Steering linkage reinstalled.
Balancer, water pump and accessories will have to wait for tomorrow.
I think Ill need shorter pushrods too, the roller lifters are about a full inch longer than the factory hyd lifters.
Valve train set up will occur later this week....
Old Dec 8, 2012 | 09:34 PM
garygnu's Avatar
garygnu
don't work on the valve train when drinking.lol dose the water pump have a bolt hole on the bottom for a bolt to butt up against the timing chain cover ?you can buy a valve train geometry checker to help measure for the correct length push rod,try jegs or summit.
Old Dec 8, 2012 | 09:40 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
If u changed the oil pump then did u measure the pick up tube/screen clearance to the oil pan? Need to get to the toy store and buy some play-dough for this or clay will work. Yep, put the clay in the pan - with gasket - and bolt her up then drop again to measure. Without this your pickup screen may or may not be a correct location to get the oil supply u changed the pump for in the first place. BTW the stock pump would have done the job.
Yes p-rod length is critical to prevent the rocker tips from side loading the vlv stems. Sorry, but i don't know how to measure for large changes. The ProForm or MOROSO checkers work for the minor length changes - but u gonn'a need a larger tool/adjustment than they can provide.
So your complaining to the choir to remove the hood and radiator/core support. U will get better at it the more times to have to do it.
Slow down and ask more questions if you want pre-emptive help. Or just tell me to shut up and i'll go away Don.
Good luck,
cardo0
Old Dec 8, 2012 | 10:15 PM
DucatiDon's Avatar
DucatiDon
All advice is welcome....its not my first rodeo....just been a long time.
Set the oil pump height already before I hammered it together.
I went with a new oil pump just since I was there....one less worry.
I have 1/2" shorter pushrods, and I just realized that while the roller lifters are an inch taller, the pushrod seat is only 1/2". its recessed into the body....so no worries. (They ended up being as close as perfect as you could expect!)
No bolt on the water pump, but it does seat up tight against the cover.
Old Dec 16, 2012 | 07:21 AM
DucatiDon's Avatar
DucatiDon
Ready to fire it up....one last pre-check......
(Doh!) I forgot to cinch up the water pump bolts...."idiot!!" LOL
Old Dec 16, 2012 | 03:26 PM
DucatiDon's Avatar
DucatiDon
AC bracket needed a little clearancing to bolt up properly. And the thick valve cover gasket caused interference between the valve cover and the air pump bracket. Otherwise its been pretty straight forward.
Old Dec 17, 2012 | 06:38 PM
DucatiDon's Avatar
DucatiDon
VIDEO:
Without looking closely you wouldnt know there were Aluminum heads and a performer RPM under there....
  #33
DucatiDon's Avatar
DucatiDon
Runs. Hurray, no big grinding explosions of metal.
Figures...the day I pull it out of the garage the weather turns to crap.
This is after 20 minutes of cam break in. (roller cam and lifters though)
The stock air cleaner fits very snugly (Too snug for my comfort) going to a drop base open element.
Now the long process of fine tuning.
This video the timing was retarded quite a bit. Set initial to 16 degrees and it idles very nicely.
I have an exhaust leak also.....
Old Dec 17, 2012 | 09:41 PM
  #34
bluedawg's Avatar
bluedawg
Don how did you check your pushrod geometry?
Old Dec 17, 2012 | 09:55 PM
  #35
DucatiDon's Avatar
DucatiDon
Blacked the valve tip with a sharpie. Assembled the valve train and turned the motor over a few times. mark was just slightly off center. I did not have a solid roller lifter to use, so its as close as i can get it with hyd lifters.
Frankly, I "guessed". Ordered pushrods 1/2" shorter and lucked out.
I was prepared to buy a pushrod checker if the shorter rods failed me,
Old Dec 17, 2012 | 10:58 PM
  #36
bluedawg's Avatar
bluedawg
If you use the checker springs they'll compensate for the spring in the hydraulic lifter. Was the mark toward the intake manifold or exhaust manifold?
Old Dec 17, 2012 | 11:02 PM
  #37
DucatiDon's Avatar
DucatiDon
Just ever slightly towards the intake side
BTW, valve covers on this car are a B@#$tch!!
And yes, the Scorpion rollers fit under stock valve covers with thick gaskets. (Have to remove the breather baffles though)
To L82 upgrade thread
Old Dec 18, 2012 | 04:25 PM
  #38
hyteck9's Avatar
hyteck9
Nice work. Anxious to hear the tuned version go.
Parts cost please? I'm about due for the same surgery
Old Dec 18, 2012 | 04:43 PM
  #39
redman76's Avatar
redman76
St. Jude Donor '09
Really sounds good when idling.
KISS ROCKS
Old Dec 18, 2012 | 04:58 PM
  #40
DucatiDon's Avatar
DucatiDon
It was well over budget.
$3800 ALL said and done.
$1500 heads
$200 intake
$200 roller rockers.
$100 pushrods.
$800 mcjacks headers
$1000 roller cam lifters and gaskets.
$100 in misc ss fasteners.
Plus chemicals and now an air cleaner.
Another $2500 and id have had a 383.
I did all the work myself, so no mechanic or shop fees.
Goes to show that a crate motor is very economical.
Next up is $5k for a 5speed conversion.
KISS ROCKS
