factory assembly, inspection marks
The 77 you found is likely to be a shortened version of the last three characters of your VIN and also serves as the job number. The job number would have appeared on the rear of the underbody (fuel tank could make it difficult to see), possibly on the passenger's side of the tranny hump -394 on this one:
394 could also have been abbreviated "94".
104 on the toe kick here:
and passenger's toe kick under the hood. "27" here.
Shorthand for power brakes.
For 68-75 while convertibles were in production, you can also find these types of marks:
437 indicates an underbody prepared for a coupe; M40 for automatic transmission meaning the AT bump out has been added; and factory alarm (UA6). Pic with 104 on the toe kick above shows the TH400 bump out on the side of the tranny tunnel. Compare with the footwell shown for #394.
Your frame might show shim marks beside the body mounts.
Parts inspector marks have been found on panels; handwritten dates have shown up.
As Mike said the numbers found on the body generally are the 'job number' which is loosely related to the vin.... sometimes.
I found the last 3 digits of the vin on the underside of one of the roof panels on my 71 as you did on your 72.
Regards,
Alan
Here's a rarely seen birdcage date.... driver's side hinge pillar, interior side. Mid January 71 built car
Dates are everywhere... seat track Julian date.
Rear shock Julian date.
The car also had numerous other crayon and paint dabs, in various places. Crayon was used to mark the number of body mount shims used, on the frame near each of the body mounts. There were also paint dabs on the steering box, drive shaft and a number of other locations.
Quanta Products in Maryland, offers a very nice "Chassis Detailing Kit", that includes instructions, paint, crayons and a frame stencil correctly configured for your car. Below is a link to the kit for a 72 Corvette.
http://www.gastanks.com/1972-Corvett...uctinfo/01-01/
People also report finding production line worker signatures on the cars.
One place is on the underside of the rear deck and another is on the underside of the hood.
Regards,
Alan
I believe the number you found on the toe board is generally considered to be the job number. It also appears on the build sheet and other locations on the body as has been mentioned.
Here's the # from my 71.
Regards,
Alan
Toe Board 186
Foot Well 186 Partly concealed by shifter console
Build Sheet 186
Might I suggest that you add the two reference texts below to your corvette library. Tom Russo devotes an entire chapter to Job Numbers and where to find them. The "Prince" book notes some inspection marks, colors, and locations, with photos examples. Both books are easily found on line.
Tooch
I think you need to be careful to differentiate between the various marks that were part of the ASSEMBLY process and thus were generally on every car, and INSPECTION marks, some of which might be on every car, but others may have been on just every 5th or 10th, or ?, car.
Regards,
Alan
The only conflict is that my tank sticker shows 374 in pencil, which is the result of subtracting 500 from my VIN of 521874. My transmission and engine match this VIN.
The Order Copy from my 71 shows both:
89… 500 less than last 3 digits of the build sequence number (589)
186….job number written various places on car's body.
Regards,
Alan
Yes Alan, Shortly after I posted I recalled being told by an NCRS inspector that, in my case, 408 is the position of my Corvette on the line during the day of production on which it was built. So, in my case, there is a job number of 374 written on the tank sticker and a production line number of 408 written on the car in various places.
10-1, 1326, 10-22
No idea what the last three are other than the 10-22 is close to the build date.
I'm not sure how much lead there was from the time the rear clip was assembled until the car started on the production line.
10-1 seems like a lot because I believe storage was an issue at St.Louis so I won't think they'd have weeks worth of clips on hand.
The 10-22 seems just about right for body assembly on a car that passed the Trim Tag station on the 24th.
Regards,
Alan
