Trailing arm shims
Old Dec 8, 2012 | 10:08 AM
naasaa's Avatar
naasaa
Default Trailing arm shims
Hi
I'm installing trailing arms to my 68 after rebuild.
I have the slotted shims from Paragon and is about to drill the hole in 4o'clock position as seen in another post regards using these slotted types shims on older vettes.
However, the ones that I have are too long to fit in the frame pocket.
Do I have the wrong shims, or can someone chime in on whats wrong here?
No way that these shimns can be tugged into the frame.
Thoughts are well appreciated.
Old Dec 8, 2012 | 10:33 AM
Mike Ward's Avatar
Mike Ward
Sounds/looks like you've got the '63 shims as discussed in the C2 section.
Old Dec 8, 2012 | 11:16 AM
redvetracr's Avatar
redvetracr
early shims were slotted?
Old Dec 8, 2012 | 12:33 PM
Alan 71's Avatar
Alan 71
Hi n,
Length of shim?
My 71 originals are 4 1/2" long with a 1 1/2" slot. They slip into place on the t-arm bolt, and drop into the pocket easily.
Has any work been done on the control arm pocket?
Regards,
Alan
Old Dec 8, 2012 | 01:28 PM
naasaa's Avatar
naasaa
My shims are of the same dimensions.
Shims are Paragons 3618K. For year 62-82
The frame has been repaired with Paragon replacements kick-up reinforcement and new #3 cross frame.
The trailing arm bolt hole is aligned per AIM frame specs.
So are you saying that the opening in the frame pocket is maybe too high at the bottom end.
I have no specification of the opening, other than the replacement parts.
That parts was corroded away on my frame.
Lars
Old Dec 8, 2012 | 02:03 PM
Alan 71's Avatar
Alan 71
Hi Lars,
It does look like you have a little bit of extra steel that has closed up the bottom of the t-arm pocket.
Does this picture help?
Regards,
Alan
Old Dec 8, 2012 | 02:42 PM
naasaa's Avatar
naasaa
Hi Alan
I'm afraid that I do have some extra steel at the bottom of the hole!
With the TA hanging freely in the pocket by the bolt, and can go as low as the shock absorber when fully extended.
I would expect the trailing arm should be able to lower at last for the full length of the shocks travel?
However, lookinh at the length of the shim, I can't see how a cottor pin can fix it with the exsisting dimension.
The location of the TA bolt hole has not changed lengthwise, but adjusted up/down as the bottom of the frame towards the new crossmember has been repaired.
Lars
Old Dec 10, 2012 | 08:22 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
Unfortunately the dimensions of the frame pocket give you no place to secure the slotted shims. You need the shims with two holes (much less convenient) so they do not come loose.
Andrew
800-442-0335
http://muskegonbrake.com
Old Dec 10, 2012 | 09:42 AM
gcusmano74's Avatar
gcusmano74
Originally Posted by naasaa
Hi Alan
Lars
That extra piece of steel welded to the back of the pocket is your problem. Look at Alan's picture. You need to somehow remove it so it 1) allows full travel of the trailing arm, and 2) allows the shims to fit as designed.
Old Dec 10, 2012 | 09:46 AM
wombvette's Avatar
wombvette
That frame has had some extensive repair work and modification at the bottom. Thats the problem, not the shims. I would just cut the shims off to fit. There is no other way.
To Trailing arm shims
