Upgrading From TH 400 to ???
Old Dec 21, 2012 | 06:44 PM
DESI6327's Avatar
DESI6327
Default Upgrading From TH 400 to ???
Going to upgrade my 68 427/390 Auto. Have no idea who makes the best Auto Upgrade
Any suggestions appreciated
Bob
Old Dec 21, 2012 | 07:05 PM
johnt365's Avatar
johnt365
https://www.corvetteforum.com/c3-tec...-pictures.html
Old Dec 21, 2012 | 07:08 PM
scottw's Avatar
scottw
If you want a overdrive, 200r4
Old Dec 21, 2012 | 08:09 PM
calvette 11's Avatar
calvette 11
Default transmission
In my 76,with a 505 big block.I use a TCI superstreet fighter and a 3200
stall converter.No breakage,plenty of go and pop.
Old Dec 21, 2012 | 10:39 PM
DESI6327's Avatar
DESI6327
Would that be a bit much for me? I'm assuming your engine is pulling a lot more HP than my 390. Also, does it have OD?
Bob
Old Dec 21, 2012 | 11:28 PM
johnt365's Avatar
johnt365
Yes it has over drive. Go back to the link I gave you in your first reply. It has lots of pictures and some very informative links in it that are essential reading for this transmission. It will give you a good central place for sources of information on this subject.
Old Dec 21, 2012 | 11:51 PM
iokepakai's Avatar
iokepakai
It's a sports car! Install a Richmond 6spd and have a blast shifting gears...
Old Dec 22, 2012 | 12:26 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Old Dec 22, 2012 | 01:44 AM
7T1vette's Avatar
7T1vette
Install a 200-4R that has been rebuilt to handle the torque and HP of your engine. TCI, Bowtie Overdrive, GM Parts, or local transmission rebuilder with good credentials.
Old Dec 22, 2012 | 07:25 AM
U17's Avatar
U17
700R4 here ... very happy ...
Old Dec 22, 2012 | 10:15 AM
pricesgarage's Avatar
pricesgarage
700r4 1987 up have one built dont get a used one
Old Dec 22, 2012 | 11:29 AM
7T1vette's Avatar
7T1vette
Either the 700R4 or the 200-4R will do the job. But, the 200 will be a direct fit in place of the THM-400. You can use the same rear crossmember and driveshaft that you now have. Those would have to be changed, if you go with the 700R4.
I went the 700R4 route for my 400 equipped '71, and wish I had gone with the 200.
Old Dec 22, 2012 | 02:58 PM
DESI6327's Avatar
DESI6327
Thanks for your time and info, 7T. Mind telling me why you wish you went w/the 200? Is it a smooth trans, does it have punch off the line and an OD?
Do you know how low first gear is. (I'm looking for the best if both worlds)
Happy Holidays,
Bob
Old Dec 22, 2012 | 03:28 PM
7T1vette's Avatar
7T1vette
For durability and 'guts', it's hard to beat the THM-400. But, it is very wasteful with lots of parasitic losses and really poor mileage at highway speeds. A properly built 200 or 700 will perform just as well, but will be much more efficient...25% or better mileage at highway speeds with the lockup clutch operational.
For lockup operation, you can purchase a lockup controller so that its function is completely automatic; OR I can provide you with the circuit for a low-dollar alternative that works well, is safe, and will cause the lockup function to drop if brakes are applied. I experimented and came up with a rather nice solution for mine.
Old Dec 22, 2012 | 04:31 PM
Street Shaker's Avatar
Street Shaker
4L80E with manual valve body !
On my 69 I had few different transmissions, M-21, Richmond 5 speed, G-Force T-56 and recently installed 4L80E with manual valve body and I absolutely love it.
Old Dec 22, 2012 | 04:53 PM
DESI6327's Avatar
DESI6327
Thanks... Sounds a bit much for my application, but ENJOY!!!
Old Dec 22, 2012 | 04:55 PM
DESI6327's Avatar
DESI6327
Always been a strong believer in... "The dumbest question is, the one you don't ask"
That said.....What is a lock up clutch, and it's purpose?
Bob
To Upgrading From TH 400 to ???
Old Dec 22, 2012 | 06:01 PM
oldalaskaman's Avatar
oldalaskaman
lock up torque converter, non lockup's slip alot, lock up's dont, gets better mpg and less heat.
Old Dec 22, 2012 | 08:29 PM
7T1vette's Avatar
7T1vette
The standard convertor for an automatic transmission does not have any mechanism for a direct connection between the convertor pump (connected to the engine output) and the convertor turbine (connected to the input shaft for the transmission). Thus, there is slippage between them, as it is only a "fluid" coupling.
The lockup clutch is a hydraulic clutch that connects the pump to turbine directly, thus eliminating that loss of efficiency in the fluid coupling.
'Overdrive', on the other hand, is an additional gear ratio in the transmission that exceeds a 1:1 ratio (input to output). Most overdrive transmissions have a .67 or .70 final ratio. Some manual 6 speed units even have two overdrive ranges: one at about .80 and one at about .60. Some high-end European cars may have automatics with two overdrive ranges, also.
Old Dec 23, 2012 | 03:20 AM
DESI6327's Avatar
DESI6327
Got it..... Thanks!!
Would a Lock Up Clutch cause hard "Gagage Shifts?" (From park or neutral to drive or reverse)
