Fan clutch question
Old Dec 26, 2012 | 07:16 PM
spf72's Avatar
spf72
Default Fan clutch question
What is the difference between a big block and small block fan clutch? I need a fan clutch for my 70 LT-1 and I can't seem to find one although I have seen several listed for a big block. They look the same, are they?
Old Dec 26, 2012 | 07:31 PM
Lil" Red Corvette's Avatar
Lil" Red Corvette
Are you talking about the fan, the clutch, or both? They both take a Hayden 2713 clutch.
http://www.haydenauto.com/upload/Hay...fan-clutch.pdf
The cars with AC usually have a better fan and more HD clutch.
Old Dec 26, 2012 | 08:02 PM
spf72's Avatar
spf72
Fan clutch. I realize the fan is different. The 70 LT-1 used a Schweitzer not a Hayden. I believe all Corvettes that year used Schweitzer but that may be wrong.
Old Dec 26, 2012 | 08:06 PM
Lil" Red Corvette
I don't know. You must be trying to find the OEM part. If so, that will probably be hard to find and expensive if you do. Good luck.
Old Dec 26, 2012 | 09:52 PM
boat196's Avatar
boat196
I believe you're correct, Schwitzer Corporation (SC) is orginial for 1970. And, from I know, BB or SB are the same.
Bob
Old Jan 1, 2013 | 07:36 AM
demoke's Avatar
demoke
[IMG]Picture URL BB Code[/IMG]
Old Jan 1, 2013 | 09:14 AM
Alan 71's Avatar
Alan 71
Hi spf,
I believe there were different fan clutch part numbers for sb, bb, and bb special hi-performance engines, and engines powerering a/c.
But according to the info in the 71 AIM the LT-! engine used the "production parts" fan clutch and fan, which I believe means it used the same fan clutch and fan as the base sb engine.
I'm looking at the info on the LT-! option pages.... UPC LT1, Sheet A4.
So I think at best you'd be looking for an appropriately date stamped sb fan clutch.
In 71 that would be a 3916139. Your 70 AIM will indicate what it was for 70.
Regards,
Alan
To Fan clutch question
